Im sick of looking for a gtr bonnet so now ive decided to have my gts-t bonnet CUT :rofl:
Has anyone here done it before does anyone know someone that can do it ???
I know it can be done cause ive seen some cars in yards with em
I need help im not sur how much trouble it will be
https://www.sau.com.au/forums/topic/128939-gtr-gts-t-front-bonnet/
I think you're crazy. Unless if you are a metal worker. It would be a hard job...
Just saw one for sale on this forum for 300 with a few scratches and dints. That + paint/repair would have to be cheaper that cut/repair/paint. And you can sell your GTSt bonnet.
You cant read? He cant find one....they are way too expensive anyway, hard to repair too.
Its fairly easy. Got a mate who did this, mark a nice and straight line, cut it good with a grinder, bend the underneath up to the new cut area.
Rivet a piece of metal on the underneath so when u lift up the bonnet u dont rip the top skin off.
Glue a piece of thin rubber over the cut so it looks neat.
Job done...cheaply.
Job done...cheaply.
There are some in the for sale section. Wreckers will have them. If it's done cheaply without paint it will look.....cheap...
Also open the door for rust where the paint comes off.
Cool for a drift pig if that's what you're after.
I would be likely to think the "chopped" bonnet will be illegal.
Even down the bottom section there? Is there ribbing on a 32 in that area? I would have thought it was simply some folded metal, just extended more than a GTR bonnet.
I would probably buy a GTR bonnet though in all honesty, you dont want some half-assed GTS-T/GTR mockup that isn't even straight! I'd wait around till you find something you are happy with, unless you 100% need it by a certain date etc..
Good luck
i found one with scratches and dents
im thinking about buying it
but even the gts bonnet is hard to sell no one wants em anyway mine has a long scratch on it to so it needs paint i was thinking maybe get the panel beater to do it all for me
im still open to suggestions
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
