For Sale:post-18599-1154756129.jpgpost-18599-1154756207.jpg
1989 R32 Skyline, 4 door sedan, white, manual, turbo, 87500 kms.
located on Gold Coast
Mods:
Near new Tein adjustable coilovers (with adjusting spanners)
Front and rear strut braces
Adjustable castor rods
Aftermarket LSD (very tight)
HICAS lock bar
3 inch mandrelbent turbo back exhaust
Pod filter
Front mount intercooler
Heavy duty clutch
Boost gauge
HKS turbo timer
Alarm/immobiliser/keyless entry
CD player, new rear speakers
New front tyres
Has safety certificate and just been serviced. $13500
Call 0414711905
cheers, Ned
Edited by loned
https://www.sau.com.au/forums/topic/128942-sold/
Sic ride cuz!
Would u b intrested in a swap 4 my fully sic 180sx? I would expect u 2 add a bit of extra cash for my troublez and considering that mine is an auto and yours is just a manual. Also my sic ride has got 4 stud hubs so it be heaps quick yo 2 change da rimz. I b tellin yew more about my sic ride so u can realize what a lucky dog u r.
1stly its got a mad neon set up that used to be in full fully decked out PC but then when my other sic mates started gettin into cars i thought i had better 2. I dunno much about carz but I drive it for the cewl image and da CRED. All the chicks dig it when i cruize around their skools yo. Anywaz, i stick the cewl neon light set up out of my bitchin PC which i sometimes play World of Warcraft on with my net mates, on my sic as 180. So now me ride flashs n it iz bitchin. Other Modz: I got all my inspiration from sic az mags like Hot4s and fast fors so my ride is all class n lets me exprezz my indidualizm. It rides on sweet AME Modelart rimz cos i saw them on about 10 hot 4 cover cars. I don't really like them but since my mates like them then i thought i betta get em 2 to imprezz my mates.
Yo haz your ride got thoze kewl windscreen washer lights? My ride does. I got dem 4 da IMAGE. My ride has also got a sik kit. Got a sic as rexy scoop and an evo 6 front bar. By da way, there iz no hole cut unda da rexy scoop coz it woulda cost 2 much. Spent da saved cash on ma engine conversion.
Engine modz - Ripped out that sr20det n upgraded 2 a ca18de. No turbo tho coz i wanna save on fuel so i can cruise 4 longer around da high skool so all da chiks can dig ma ride. Itz all sweet tho coz i got me one of dem sik az speaker set upz in ma engine bay that makes a blow off valve sound when eva i change gear so itz no one knowz that it doeznt have a turbo anymore.
B4 a let ya hav ma ride tho i wanna get a pic of it in riders rides in hot4s. that way more chicks can dig my awsome cr8tion, n then sleep with me. I normally pic all da hot chicks up off da internet when im playin world of warcraft but iv already slept with them all in world of warcraft so i thought i should try it in the real world now.
Im gunna need an inspection of your ride b4 i let u sell it 2 me. I liv in Bankstown with ma parents so if ya could organize for it 2 b brought down here so i could check it out, kick ya tyres n shit, then yeah.
sic180auto
https://www.sau.com.au/forums/topic/128942-sold/#findComment-2399023
Sic ride cuz!
sic180auto
haha you crack me up, wierdo....
Edited by loned
https://www.sau.com.au/forums/topic/128942-sold/#findComment-2399983
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
