gday guys and gals
installed a batmbl dump pipe + hi flow turbo. great products!! got it installed yesterday but they left the heat shield off because i assumed they couldnt bolt it back on due to the tight fit. modified the heat shield today with the good old angle grinder to make it fit using just one exhaust bolt thats easily accesible. durring the process took the other 2 bolts out to test fit. now i can hear the turbo spool very early, below 2k even before induction noise starts. is this normal or do i have an exhaust leak? bolts not tight enough?? they are pretty tight but i dont want to over tighten them incase i snap them which ive been doing lately...lol
https://www.sau.com.au/forums/topic/128943-dump-pipe-and-quick-spool/
I know.. its a VERY VERY tight fit indeed..
Esp that stupid aircon pipe in the way of the wastegate pipe.
would have been better if the wastegate pipe came over a little more to the left n up, and the 02 sensor down the bottom..
But anyways think i hear early spoolin sounds as well..
But otherwise quailty is excellent. you can deff feel the incresae in power.. love it..
but now cravin for more power..
Edited by siddr20
You would be supprised inthe increse in low spool now and i have stainless
one and from under the car you can hear it pulsing in the pipe ,so
it wount be a leak and you would definatly hear in the bay.
so all is good , just check them in a week o so
as they man need to be retorqued.
thanks guys.. ill check it in a week to re tighten em up.
car drives silky smooth now throughout the rev range. its fantastic!!. does anyone think the direct contact with waistgate pipe and the air con pipe will cause any long term problems?? i was thinking of modifiy the aircon pipe mount to move it over a tad.
Yes it will, even tho the aircon pipe has heat wrappin around it already!!
Sine it sits like a mm off, during summer it will melt that wrapping for sure.. IM gonna reallocate that pipe soon.
I would wrap it up just incase, coz you never know. Just imagine the temps down there on hot days.
    • Aye, everything is being touched and all the parts that are responsible for the oiling issues are also fixed. (Crank collar, billet prp oil pump, head return to sump, yada yada yada)  Everything used is of reputable brands like greddy, prp etc. My tuner did mention we’d keep the torque on the “lower” side.   glad to read that my engine won’t blow up on me lmao
    • It's a fuel pump. EFI, high pressure, but specs otherwise unknown. A bodge job.
    • 800 engine horsies is fine. Will need all the obvious upgrades. Rods, pistons, oil pump, big sump, sump breathing mods. Build for revs because revs are power with less stress on the bottom end compared to boost. Keep the torque down in the midrange, either by limiting boost or timing.
    • Hiya guys,    i’m currently in the process of getting my rb26 built. everything is being replaced with better/upgraded parts or oem when that’s good enough (which isn’t alot lol). someone earlier mentioned to me that i’ll be screwed cause the iron block can’t take 800hp (to the engine, not wheels) which is what it’s being built for.  what do you guys think about this, am I cooked or na? The guy building the engine will also do the mapping as he is “the guru of old nissan engines” here in Belgium. I know the mapping makes a huge deal so i’m not concerned about that.    I honestly he’s talking shit cause he’s that kinda guy but a second opinion never hurt anyone! cheers in advance! 🫶🏻
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
