gday guys and gals
installed a batmbl dump pipe + hi flow turbo. great products!! got it installed yesterday but they left the heat shield off because i assumed they couldnt bolt it back on due to the tight fit. modified the heat shield today with the good old angle grinder to make it fit using just one exhaust bolt thats easily accesible. durring the process took the other 2 bolts out to test fit. now i can hear the turbo spool very early, below 2k even before induction noise starts. is this normal or do i have an exhaust leak? bolts not tight enough?? they are pretty tight but i dont want to over tighten them incase i snap them which ive been doing lately...lol
https://www.sau.com.au/forums/topic/128943-dump-pipe-and-quick-spool/
I know.. its a VERY VERY tight fit indeed..
Esp that stupid aircon pipe in the way of the wastegate pipe.
would have been better if the wastegate pipe came over a little more to the left n up, and the 02 sensor down the bottom..
But anyways think i hear early spoolin sounds as well..
But otherwise quailty is excellent. you can deff feel the incresae in power.. love it..
but now cravin for more power..
Edited by siddr20
You would be supprised inthe increse in low spool now and i have stainless
one and from under the car you can hear it pulsing in the pipe ,so
it wount be a leak and you would definatly hear in the bay.
so all is good , just check them in a week o so
as they man need to be retorqued.
thanks guys.. ill check it in a week to re tighten em up.
car drives silky smooth now throughout the rev range. its fantastic!!. does anyone think the direct contact with waistgate pipe and the air con pipe will cause any long term problems?? i was thinking of modifiy the aircon pipe mount to move it over a tad.
Yes it will, even tho the aircon pipe has heat wrappin around it already!!
Sine it sits like a mm off, during summer it will melt that wrapping for sure.. IM gonna reallocate that pipe soon.
I would wrap it up just incase, coz you never know. Just imagine the temps down there on hot days.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
