have a skyline diff for sale in good condition...not noisy...not thrashed. genuine turbo diff. any reasonable offer considered. if you want to, you can email me at [email protected] or post here
can freight..buyers cost. we are in melbourne, victoria
https://www.sau.com.au/forums/topic/128949-fs-r33-gts-t-complete-irs-rear-end/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
