howdy,
thanks for at least looking at this thread. i know it's in somewhat the wrong section, but it's still skyline related.
I need to get a high resolution R32 Skyline badge image. the 'S' from the bonnet/wheel centers to be specific. not a photograph though, needs to be a clear printable image.
thanks in advance, i'll explain why in a few days :miner:
-matt
https://www.sau.com.au/forums/topic/128951-need-r32-skyline-s-image/
alrighty, last bump. i need an image by saturday but can survive without one. apparently a high res camera shot will work.
Seeing as how it'll be with me for a while, may as well tell people why i need the image... i'm getting an R32 emblem tattooed on my right calf. so step one is just the S (because i'm getting 3 other tattoos that day and dont want to be in a little room for a full day ;)) and when i go back for touchups, "Built With Spartan Air" will be added.
thanks you guys... r32 gts-turbo, that isnt an R32 Skyline badge, is that may be the R33? we dont have them here so i've never really looked into it :O
slimjim, perfect. the one from the wheel center is what i need. i recently sold my stockers and the best image would have been from the steering wheel.
huge appreciation goes out to you guys... less than 2 days until i get it done for good :)
i just got home, it's still really fresh and nasty lookin, but i'm so damn proud of my latest addition :D
now no matter what, i'll have an R32 with me :)
dont mind the little bit of blood and the house robe, it's hard to clean there and it's too soon to shower :)
Edited by entelijint
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
