howdy,
thanks for at least looking at this thread. i know it's in somewhat the wrong section, but it's still skyline related.
I need to get a high resolution R32 Skyline badge image. the 'S' from the bonnet/wheel centers to be specific. not a photograph though, needs to be a clear printable image.
thanks in advance, i'll explain why in a few days :miner:
-matt
https://www.sau.com.au/forums/topic/128951-need-r32-skyline-s-image/
alrighty, last bump. i need an image by saturday but can survive without one. apparently a high res camera shot will work.
Seeing as how it'll be with me for a while, may as well tell people why i need the image... i'm getting an R32 emblem tattooed on my right calf. so step one is just the S (because i'm getting 3 other tattoos that day and dont want to be in a little room for a full day ;)) and when i go back for touchups, "Built With Spartan Air" will be added.
thanks you guys... r32 gts-turbo, that isnt an R32 Skyline badge, is that may be the R33? we dont have them here so i've never really looked into it :O
slimjim, perfect. the one from the wheel center is what i need. i recently sold my stockers and the best image would have been from the steering wheel.
huge appreciation goes out to you guys... less than 2 days until i get it done for good :)
i just got home, it's still really fresh and nasty lookin, but i'm so damn proud of my latest addition :D
now no matter what, i'll have an R32 with me :)
dont mind the little bit of blood and the house robe, it's hard to clean there and it's too soon to shower :)
Edited by entelijint
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
