Hi
I need to get some mats made up, ive got a set of 5 that are shagged, so ive got some templates, but im not sure where to get them done as im up in Broome. Anyone had mats made up? maybe even logo'd and are willing to recommend or know somewhere to get some done? Preferably with a rubber no slip backing and the heel pads.
thanks in advance
cheers
Evil
https://www.sau.com.au/forums/topic/128952-custom-skyline-mats/
Check out the group buy section - Stagea owners are having a group buy and Some skyline owners have ordered with a discount as Sau members.
Here's the link :)
http://www.skylinesaustralia.com/forums/in...howtopic=123059
Edited by StageaGirl
Thanks for the reply guys, ive seen that group buy and checked out the site with the skyline mats. The problem is that as i live in broome, the carpet on the transmission tunnel gets raped by red dirt. So its really the set of five that i need, theres nothing too wrong with the middle mat, its just i would much prefer the set to match :(. Theres a motor trimmers/upholsterer in broome, but they never got back to me, and they dont really have rubber backed carpet/large selection of carpet.
cheers
Evil
if your interested
i can get you a set of second hand r33 gtst or gtr mats from yahoo auctions
heres an idea of wat i can get
should be able to get these for around $100-$150
GTR set (these will sell for about double the price of the above matts)
thanks michael
Thanks again for the info.
I actually have a set of genuine mats with the skyline logo riveted on a metal plate, like the first set of pics but a different metal plate attached, im assuming they are SI mats. They fit perfect but the drivers side heel area is stuffed, and the rubber backing is falling to bits. I bought them as a template, so i could get some made up that werent too plush, as the red dirt will just get trapped. Pretty much a custom job, but thanks for the info all the same.
cheers
Evil
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
