  • Replies 128
Posted Images
I plan for it to be an all round car, street, drift, drags, track, and shows.
I've had the car only 12 months, mite take a couple of years but thats the intension to build an all rounder.
I have coil overs and wheels comming next month.
The car is currently sitting in the workshop , im completing the next series of modifications.
  • 1 month later...
Bit of a decent update,
Im going to include alot more pics this time just to give you guys an idea on how much work goes into getting things perfect. So much work goes into aftermarket products to make them fit like oem products.
Heres a few pics of my cf boot, the carbon has been laid perfect but the underside moulding was terribly out of shape cause the boot to fit okay but nowhere near the standard I want to achieve for this car. So i had to cut and remove the shape out of the boot and remould it to fit perfect, this took hours and hours of work to get right. What I ended up with is a perfect fitting cf boot which is really hard to get.
Reshaping of the boot, this was only the first stage I didnt get pics of the next stage.
Filled and primed
Finish coat, still had a few coats to go but you get the idea.
Boot completed.
Okay heres a bunch of pics where I am up to atm including the new front bar. Gives you guys an idea why I chose the black over the orange! Please feel free to comment
Just a tip i found with taking pics of my car in sunlight; as your car also seems to have a pearl.
With my camera i have to press the button half way to focus, then continue pressing it to take the photo. If yours is the same, try to focus on something lighter (whiter) that is roughly the same distance from your car, then turn the lens to your car to take the photo. I found that the pearl "fools" the camera and the pic ends up over exposed.
Just to show you an example, i've added two pics of photos of my car.
This first i focused on my car, you can see the shot is totally over exposed. Have a look at the white 33 in the left corner, and the sandy gravel.
This second pic i focused on the white car, and i prefer to see my paint colour in this type of shade.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
