Help required,
I've been thinking long and hard on installing extractors to my R33 and require some advise as to how to install them and will I get any power increase. Currently I'm running standard Turbo with 10lb boost, front mount Intercooler, Jaycar air and fuel adjuster, Dump pipe, Turbo back 3inch exhaust.
I have searched high and low on the DIY and found very little info. Any hints or help appreciated on how to install the extractors or should I get a professional to do the job.
https://www.sau.com.au/forums/topic/128982-installing-extractors-to-an-r33/
You can do it yourself.
I personally have not done this by myself, so you might not want to listen to everything i say. But i have helped a friend do it.
Depending on your mechanical abiltiy, it's not actually hard to do.
All the intake piping and stuff all over the place comes off.
The most difficult thing about removing the manifold is that the bolts will be very tight and in hard to reach places. You will most likely break bolts.
Also, you might not be able to get the stock manifold back on after you take it off, because it might have warped.
dont bother doing it if you're sticking with the stock or hi-flow stock turbo.
if you are going to do it anyway i'd definatley get ALL of your manifold studs replaced, if they dont break now, they will later. when i took my exhaust manifold off i snapped around 6 studs and replaced all of them. nissan sell the studs pretty cheap. you'll get the full set of 12 for under $20, it'll be around the $12 mark if you're an SAU member.
anyways, dont do it if you're looking for big gains on the stock turbo. the money can be better spent elsewhere.
Thanks guys for your replies,
Unfortunately, I have bought the extractors and I will go through to put them on. However, I might get an exhaust place after hearing what you guys had to say, do I need the added stress.
Also in the near future I will be upgrading to a larger turbo so I thought of getting extractors.
All comments appreciated.
Chris G, Sydney :sorcerer:
If you don’t mind me asking, how did you replace the studs, I had a look at the engine bay and I just can't fit anything on the side, replacing the stock manifold is a big task but the studs now I'm really concerned so I rung around a few exhaust places in Sydney and they quoted from $350 to $200 to install. One place told me no matter how much you spend $1000 to $100 for the manifold they all crack within 12 months and you would probably get an extra 10kwts of power.
I'm just waiting to get it delivered and then I will decide to go through with it or re sell it for a loss.
Thanks again
Chris
thats bull about the extractors cracking...
if u buy quality extractors than they should last!
With the studs they will just screw out of the head.. may be tight though
I agree with you, but this guy who I won't name claims he does expensive cars and manifolds, no matter how expensive or cheap they are will crack within 12months and he guaranteed me it would happen. Driving like grandpa or unleashing hell pedal to the metal, the amount of heat generated by the turbo will eventually crack the pipes were the joints are welded.
What come back do I have.
Maybe others may want to put their 20c worth about expensive or cheap manifolds.
CG
:laugh::3some::whistling:
no its not I have seen it a few times...if the manifold doesn't sit flat some doods just tighten up the bolts and hope the slack will be taken up in the gasket - bad idea...u get some stress in unwanted spots...then it cracks under the heat over time.
Edited by khunjeng
Update,
I received the manifold and took it to the manifold place and he laughed, he asked if I had an extra $1000 to install a top mount manifold because I would need new exhaust, oil and water lines to the turbo and it would be a head ache to install.
He told me the manifold I have is ample so I re- sold the manifold at a loss, I’m not going down that path again.
I saw my mechanic who took my car for a drive and adjusted the Jaycar fuel and air adjuster by road tunning the car, it goes allot better than before. Now all I need is a fuel cut defender so i can increase my boost.
The skyline screams.
Thank guys for your input. :sorcerer: :(:D:yes::(:):):laugh:
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
