Folks, I have the following laptop forsale. It was purchased in error and now I really need to get rid of it. I upgraded the Memory, hard drive and optical drive. Here are the details:
Dell Inspiron 1300 Intel® Pentium® M 735 Notebook
E-VALUE CODE : N540818
ALL OF THE BELOW SPECS SELL ONLINE RIGHT NOW FOR $1419
PentiumM 735 1.7Ghz 2MB Cache
512MB DDR2 (1x512)
80GB 5400RPM Hard Drive
15.4" WideScreen
DVD Dual Layer Burner
Gigabit Lan, Intel 802.11G Wireless, 56k Modem
WinXP, AntiVirus, Microsoft Works
Deluxe Dell Carry Case
1 Year Onsite Warranty (363 days remaining)
Keen to speak to any serious buyers. Will drop off anywhere in Metro area. Unable to demo as I wish to keep sealed - Dell paperwork provided from order.
Chasing ~$1350ono
Jai
0422 925 440
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
