took my car to an undisclosed location last week to have a wheel-alignment done.
the back had a bit of toe in from the recently fitted hicas lock bar. front and rear alignment, easy job? yeah!
gave them the car at 8am, handed over my money, and picked it up at 5pm.
it seems to drive fine, ie the wheels were straight, it drove in a straight line, $55 well spent.
whilst driving to the city tonight, i noticed a slight clicking sound coming from the rear, sounded like a dodgy CV joint click. so i had a quick look under it, couldnt see much really, so i planned on getting it checked out on monday.
then when driving from the city to pick up a friend from freo, heading down the freeway, just as you pass the city, and hit the newly done zig-zag part, on the last zag left, the rear suddenly felt like i was drifting... at 80km/h.. down the freeway. NOT cool.
so i quickly found my way over to the right hand emergancy lane, got out of the car and sawmy rear right wheel had taken on a new position with about 10 degrees toe in.
after further inspection under the car, it would appear that the arm that joins the right rear hub to the hicas, had become detached from the lock bar, thus allowing the right wheel to flap around as it pleased.
the only thing stopping the wheel from flapping around violently was the rubber 'boot' that stops dust/dirt getting into the threaded joint.
at 80km/h on a sloping surface, whilst turning left, and accelerating out of the corner, you dont really want the wheel bearing alot of the cars weight to suddenly change its orientation.
i had the car towed home, no way was i driving that any further. (i couldnt even come up with a cool story, like i was doing this MASSIVE BURNOUT, and it must have come loose from the sheer power)
so at 8am on monday, the undisclosed location is going to receive a phone call from yours truly, and they will be explaining how/why this happened, rectifiying the problem, and i expect some form of compensation for the trouble, and the tow home.
</rant>
Jeez, thats terrible! Lucky the roads weren't wet or you didn't have an accident and get hurt. Good luck with calling them, update us with what they say!
I am always paranoid after picking my car up from tyre places etc... there must be occasions when they forget to do up the nuts properly.
My brother (lives near Sydney) was driving across the Harbour Bridge one day when he heard a strange noise & the car was shaking. Pulled over straight away, and seen that 3 out of 4 of his locknuts on one of his front tyres were missing, and the 4th he could undo with his fingers, so the wheel wasn't very far off coming off his car completely. The tyres had only been replaced that day or the day before, they got a phone call too!!
Like he said. I'd be chasing the installer of the lock bar.
i installed it myself, and i know it was tight because i borrowed a massive wrench to get it cranked up as tight as humanly possible.
rang them first thing this morning (on my lunch break now)
spoke to the manager, they are going to re-attach the tie rod arm to the lock bar, align the wheels(front and rear), pay for the tow, and give me a voucher for a free wheel alignment.
he was quite apologetic about it, and finding out why that part of the tie rod arm was loosened, rather than the other end.
-1 for the event occuring in the first place, but +1 for their effort to rectify the problem.
i think its all sorted now...
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
