took my car to an undisclosed location last week to have a wheel-alignment done.
the back had a bit of toe in from the recently fitted hicas lock bar. front and rear alignment, easy job? yeah!
gave them the car at 8am, handed over my money, and picked it up at 5pm.
it seems to drive fine, ie the wheels were straight, it drove in a straight line, $55 well spent.
whilst driving to the city tonight, i noticed a slight clicking sound coming from the rear, sounded like a dodgy CV joint click. so i had a quick look under it, couldnt see much really, so i planned on getting it checked out on monday.
then when driving from the city to pick up a friend from freo, heading down the freeway, just as you pass the city, and hit the newly done zig-zag part, on the last zag left, the rear suddenly felt like i was drifting... at 80km/h.. down the freeway. NOT cool.
so i quickly found my way over to the right hand emergancy lane, got out of the car and sawmy rear right wheel had taken on a new position with about 10 degrees toe in.
after further inspection under the car, it would appear that the arm that joins the right rear hub to the hicas, had become detached from the lock bar, thus allowing the right wheel to flap around as it pleased.
the only thing stopping the wheel from flapping around violently was the rubber 'boot' that stops dust/dirt getting into the threaded joint.
at 80km/h on a sloping surface, whilst turning left, and accelerating out of the corner, you dont really want the wheel bearing alot of the cars weight to suddenly change its orientation.
i had the car towed home, no way was i driving that any further. (i couldnt even come up with a cool story, like i was doing this MASSIVE BURNOUT, and it must have come loose from the sheer power)
so at 8am on monday, the undisclosed location is going to receive a phone call from yours truly, and they will be explaining how/why this happened, rectifiying the problem, and i expect some form of compensation for the trouble, and the tow home.
</rant>
Jeez, thats terrible! Lucky the roads weren't wet or you didn't have an accident and get hurt. Good luck with calling them, update us with what they say!
I am always paranoid after picking my car up from tyre places etc... there must be occasions when they forget to do up the nuts properly.
My brother (lives near Sydney) was driving across the Harbour Bridge one day when he heard a strange noise & the car was shaking. Pulled over straight away, and seen that 3 out of 4 of his locknuts on one of his front tyres were missing, and the 4th he could undo with his fingers, so the wheel wasn't very far off coming off his car completely. The tyres had only been replaced that day or the day before, they got a phone call too!!
Like he said. I'd be chasing the installer of the lock bar.
i installed it myself, and i know it was tight because i borrowed a massive wrench to get it cranked up as tight as humanly possible.
rang them first thing this morning (on my lunch break now)
spoke to the manager, they are going to re-attach the tie rod arm to the lock bar, align the wheels(front and rear), pay for the tow, and give me a voucher for a free wheel alignment.
he was quite apologetic about it, and finding out why that part of the tie rod arm was loosened, rather than the other end.
-1 for the event occuring in the first place, but +1 for their effort to rectify the problem.
i think its all sorted now...
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
