Need help on this issue cant seem to find if it has been done bought up or anything using the search, so hear we go n e way, leaking coolant behind heater box need to know how others have fixed this problem and how long does it take, only started 2 days ago and noticed today, carpets all wet which is pretty shit, if someone can help me asap and if a DIY on how to fix this problem, would be great and handy
Thanks
https://www.sau.com.au/forums/topic/129032-leaking-coolant-behind-heater-box/
http://www.skylinesaustralia.com/forums/in...showtopic=32611 bugga of a job done my sons a month or so ago
Cheers mate, think ill go with the bypass trick had a look at the guide and not looking forward to pulling entire dash out, so ill bypass it tommorow, can someone confirm a couple of things for me, According to the bypassing guide, they used a inner hose of diameter @21mm, is it possible just to join the hoses with two barbs and another hose, if so what would the diameter of the barbs be, would they be the same at 21 mm, or go for 20 mm barbs to really clamp the b@sterd of the thing down
Stupid bloody heater thing, lucky not so needed up here in QLD as much as down south, also after this i need to source a wet carpet cleaning service, so they can wash the carpet or a self service carpet cleaner similar to the one at 8 mile plains carlovers but i think that one is out of service STIl|LL last time i checked it was. or on another note would it be worth while to replace the underlay/sound deading stuff with new stuff or let it dry? as far as i know ethylene glycol substances are acidic? ie. radiator fluids,
Cheers Adam
Cheers Adam
Hi just did mine .didnt do all this though. just took out the glovebox and air con part. unscrewed the plastic hoses from the core (4 screws in each) slid the core out the side. slid the new one in , put some silicone gasket round the silicon o rings and screwed the plasic hoses back on. DASH not touched. might just be that all is wrong with yours is those silicon seals either way if you can get the 300zx one its a quicker way of fitting
when we have heater core leaks at work, they generally try and just dry the carpet first! hot air gun and a bit bit of deodouriser for example... it's alot easier than replacing the carpet especially if you have just had the pleasure of removing the dash!
i'd say dry it and see how it goes... should be sweet!
Mine did the same thing about a year ago, and had it bypassed. Now I have bought a replacement core to go in and will, eventually, one day, maybe this centry, pull my finger out and look at whacking it into my stagea. But I really dont want to take apart the whole dash to, so going to look at accessing it through removing the glove box and trying that angle, mainly because I have a front passenger side airbag, and dont really want that going off at all :D
Waiting for a copy of FAST so I can try to firgure out how big a job it is going to be.
Good luck with yours!
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
