Hey fellas, lately i have noticed i get a slight intermittent 'clunk' in the rear end of my car when taking my foot off the throttle when the revs are constant... I have NEVER dumped the clutch or done burnouts... i do occasionally take off bit hard off the lights for a run but that’s bout all... Could something be loose? What should I look out for? Is my Diff/tailshaft on the way?
Another question... what is the difference between 1 way, 1.5 way and 2 way LSD diffs?
Regards,
Sarkis
https://www.sau.com.au/forums/topic/129051-wierd-clunk-in-the-diff/
hey dude.
(ur not rashal sarkis that used to go the st pauls are ya?)
anyways.. i got the same issue. im guessing my diff is stuffed, cos i tried to be cool my the guys on the movies and did alot of drifting.
does anyone know how much it costs to fix this problem? (ie how much for a new diff??)
check U-joints - get under the car and turn the drive shaft back and forth by hand check for play. there should be no side to side (i mean like left to right or up and down) there should be a little turn-play but not much...
check diff mounts and subframe mounts - those are the rubber mounts that are inbetween the car and the sub-frame/diff.
if its happening during deccel or accel its prolly the diff mount..
and last but not least check YOUR LUGNUTS! seriously the come loose sometimes, happened to me i felt stupid haha...
good luck...
About ur clunk noise.... i had it in my 200sx sometimes turned out 2 of the bolts on the rear subframe where about half a turn loose. tightened them up and it stopped. mechanic or suspension shop is the place to go. cheers paul
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
