  • Replies 49
^^^^^^^^^ with some luck^^^^^^^^^^
And what is that supposed to mean?? My R33GTS-T is running 12 pound and has everything on the list EXCEPT the new turbo and I am running an easy 205 rwkw. I could push it further but it is a daily driver so it is in a safe region of tune.
lol u seem to be learning a lot every day.....good on ya
Ahahah learning is good, its excellent lots of people here really know there stuff so where better to ask questions, ive looking at prices like on average how much it would cost me just for parts without labour and i decided it would just be easier to by a skyline with everything on it.
Do yourself a favor and stay stock the car's already a weapon. Now just add those little things that make it look grate and ride how you want it. GTS-T power isnt that bad to start with.
Thats so true a mate of mine has a 33 gts-t and that thing flies according to me and its stocko.
but who knows when the stock turbo/turbos will let go????pushing it too hard will definately decrease its lifespan.....especially when its got ceramic wheels. that is something you can not control.
only with lower compression can you run that kind of boost
eg: a metal head gasket
u can run whatever the thickness of the gasket is
eg; 1.8mm gasket=up to 1.8bar of boost
this is refering to a stock engine internals setup and many 9 or 10 second cars in usa etc run stock internals and massive boost
incorrect
you have to have all the correct measures inplace to run bigger boost like 20psi+ injectors, computer, front mount, big fuel pump and fuel system is probably most crytical to stopping detonation. and a good tune. from what i know anyway.....correct me if im wrong.
with a healthy motor. Ull just need a fuel pump, fmic, full turbo back exhaust, 11psi, air filter :P 200+rwkw wont be hard to see :D
Ahhh thats good to hear because after a certain amount of kw's you gotta start upgrading brakes suspension etc etc cause traction starts to get a little dodgy and i dont wanna spend that much money 200 rwkw would make me happy.
You know, I agree 100%. When i was buying the thing I thought I would mod it, but now I have decided why, its quick enough stock and I love the idea of reliability. Will be staying stock engine wise for sure, not really interested in spending money on it at all now, maybe fix the silly low ride height and it will be plenty.
i just wich the stock turbo had a steel exhaust wheel. mine pulls like a train on stock turbo at 14psi. i have a remapped ecu. on the stock ecu and at 12psi i got 204kw. and 14psi feels noticably faster. i'm just saving up for a new turbo. i would like to get to about 230kw..... till i get there, then i'll want more. when i forst got it i said that i'd be happy with 200kw. now that i'm at 200kw i want more.
when i got the car it was bog stock and i found it dissapointing compared to my last car. i thought it was going to be quicker (my last car had about the same power as a stock r33). then i stuck an exhaust on. it was a bit better. then some more boost. then i stuck a fmic on it. better again, but still not enough. did dump pipe and cat. then dyno'd at 204kw. then got a hold of a remapped ecu. made a tiny difference. then screwed some more boost into. its fun now, but could be a bit better.
get it to wheelspin uncontrollably, then screw in another 5psi!
jus get urself a set of dba slotted discs and blitz pads for ultimate stopping power. I have a set of coil overs in my car with drift pineapples and what not in my car. Traction isnt an issue :thumbsup: unless u dump 2nd at 6,000rpm then you will be in trouble. But none the less. Puts power down very well, Handle awesome on the street. Very safe and reliable 200+kw
you can still build a highly-modified car with reliability at the same time, as long as the right things got done by the right people.......
Yeah you just have to be willing to spend the money to do it right the first time, but I figure by that time I could just get something which is quicker stock out of the box :thumbsup:
I feel that a lot of mods are a compromise though, like heavy clutches, tight diffs and hard suspension being a compromise on drivability and comfort, aftermarket ecu's being a compromise on some factory drivability features and fuel consumption etc.
Its all and good if you like these things are willing to accept them, but I just feel i dont really have the time of day for them any more.
yep , the RIGHT things by the RIGHT PEOPLE being the key words there
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 馃槩, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 馃
