ok guys, i recently bought a new high flow cat from the GB in teh for sale section as i knew what i have on the car is been 'broome-sticked'... im under the car atm and on the new cat there is a sockt for some sort of exhaust temp? sensor. the old one doesnt have any socket and i dont have the sensor under the car, see the pic as i think thats where the sensor has been cut from..
1) what is the sensor and can i get a new one?
2) sould i drive the car without the sensor and with an empty socket or should i put the old cat back on untill i get a new sensor?
car is a 32 gtst btw
Edited by RCEBNR
https://www.sau.com.au/forums/topic/129153-cat-sensor/
It is the exhaust overheat sensor which brings the light on the dash up if the cat gets too hot.
Nothing to worry about and seems to have absolutely no effect on the vehicle.
You will have to find a suitable plug to screw into the hole on the new cat as exhaust gas will leak out.
Cheers
Ken
https://www.sau.com.au/forums/topic/129153-cat-sensor/#findComment-2388668
yep, it's no problem. you could just weld it up if you want. or take it down to a coventrys fasteners place (or similar) and get them to find the right bolt to plug it up (use some high temp sealant on it too).
https://www.sau.com.au/forums/topic/129153-cat-sensor/#findComment-2388729
  • 1 year later...
  • 2 months later...
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
