Should I Buy?
Rekin
 Share
17160?????? thats a lot man, my r33 cost me 17500....id think about this again man....
$17160 is what i assumed maclarenf1 total cost of his r33 is.
im comparing it to my estimated value of $13700 if i go ahead with this deal.
  • Replies 134
Posted Images
id wait for a cheaper one.. to be honest ive got no clue about the current prices on cars... but as others have said arent r33's 15-16k these days and getting cheaper every day ? r32 seems expensive to me...
yap...thats about right actually.....cost me $980 for insurance.....and cos i brough from aussie owner ...came with aussie alarm.....and 17inch wheels......and cat back exaust...and nice stereo...(aussie one with MP3 and all)..
shit sorry man, i got the flu and im only reading bits and pieces....
Thats a very nice r33 - i think i seen it before. Do you drive around the Monash area (mount wav, glen wav, clayton etc)?
Just got back from Racepace. My car was the only one missing a GTR badge haha. Saw a couple of SAU stickers on some. A black r32 gtr and a silver r33 gtr.
Racepace checked out whole car including compression; (140,135,145,140,135,145) and said it was good mechanically and whole car clean.
Couple of minor problems which need to be fixed for road worthy which Ben explained are common faults for this age of car. All will be fixed as RWC included with car.
Thanks goes out to Ben and his team at Racepace for inspecting the car and providing honest results.
Now to arrange daypass and vicroads rego uff~
- Patrick
thats meanr34's car, dave. he sold it too mook
oh...he had different wheels when he sold it to mook though...34gtr on the front and some 5 spokes on the rear....i might have to PM him to ask him for offsets
- Patrick
nice mate.....hey.....if racepace says its all good....then who are we to say otherwise......went there ages ago to fix a turbo timer and there had GTR's left, right and center........hehehe.....but atlest try to get it with rego....
That looks like Dales car - from ages ago....
He and his wife had one each IIRC.
He was the first SAUer I met at the Christmas BBQ in 2004 at Elwood. Havent seen him at any events since though :D
yap....i do.....i work in glen wav and mate's live near monash uni..
$13700 still seems like a lot. You could easilly find an R33 for that prince (S1). They are getting cheaper and cheaper. Plus for that money you get a 2.5lt engine and a better gearbox. Anyway, good luck with the purchase.
Preference really, id prefer a clean r32 over a s1 r33. Im P-Plater so not going to risk it with the power/weight ratio regardless of how many people are doing it.
RWC should be ready in 2 days, I heard Vicroads are againts p-platers rocking up with imports to get rego. Any one had issues trying to get rego under their name? For full rego not rego transfer ;)
why is everyone comparing a good condition 32 to random cheap 33's? ;)
If someone is after a nice 32, why does it matter what price 33's go for? need to compare apples with apples :)
IMO i don't care how cheap 33's get, if i'm after a nice 32, i'm after a nice 32.....
anyway, it seems like racepace have given it the all clear, so as long as Patrick is happy then its sweet :)
hooray! some r32 support!, the r33 owners were eating me alive :)
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
