can't go more than 2" more than standard.
ie, R33, no more than 18"'s (16 standard)
R34, no more than 19"s (17 standard)
for fords for example, an AU falcon can go to 19's, because the XR models came out with 17's as the largest factory option.....
so in theory it should be the same for a skyline.
ie R34 can go to 20's, because the GTR has 18's.
they go by the largest factory rim/tyre combo....
but there's more rules to it than that...rolling diameter cant change by more than 15mm i think it is...stuff like that
  • Replies 134
Posted Images
haha wtf.
Pivot wasnt included but it had the sticky stuff which needs to be cleaned.
Accident repair history? Im guessing it was the back. As my boot lid is missing stickers on both sides and probably had a respray. If it was serious racepace would have picked it up right? haha
Dropped by at the meeting today for a short time. Showed Paulr33 the car, seemed to be all good.
How'd you manage to find that link?
- Patrick
i remembered seeing that nismo sticker on your bonnet somewhere so i had a look around...
makes you wish you had just bought it from prestige for the cheaper price eh :)
Power outage due to wind lost my reply -.-
So Ill make this reply short :)
Prestige listed for $11k, i bought it for $13k, which allowed me to test drive and take to pre-inspection workshop before buying. A major service was included along with rwc and any problems found from inspection. Also being able to drive the car after paying, instead of waiting months for importing. I guess that could be worth the extra $2k? haha
Vicroads bumped me back due to the CIN listed 16's when my car had 17's on. The guy was an asshole and just wanted to make my day worse.
Seller swapped and removed wheels/spoiler free of charge and put it all back on.
Have some weird sunshade applied to the rear window. Its like a tint but its mesh to block out the sun from ruining the interior im assuming. Well turns out nothing can stick on the mesh...My brake light fell off and so did my p-plate with blutac and suction cup.
Will try and go back to seller to remove shade and re-apply the brake light.
Spent about 15mins in carpark trying to turn off alarm as i didnt know which buttons on the keypad. I think the keypad battery is flat and hence no buttons were being recognised haha.
That ecu reset seems like a good idea but first i need to work out how to disable this alarm :P
Also like the induction sound from the apexi pod. nice and loud hehe.
- Patrick
Anyone happen to have a stock black r32 gtst wing lying around?
Might leave the gt spoiler brackets on and fix the other holes by mounting the stock spoiler back on! and if im bored attach both spoilers on for maximum downforce! hehe.
Everyone seems to go spoiler-less or GTR wing so there must be plenty of them around. Hopefully someone could donate or offer one for a low price :huh:
Thanks
In my 32 4door there are two buttons next to the hand brake.
The first one (The fan button) i rekon would control the factory air purifier on the rear shelf. Mine didn't work any more so i ripped it out.
The second one makes an antenna with a little orange light on it pop out of my front bar. Either so i can see where my car finishes and the kerb begins. Or so i can laugh at people do a double take when they see it go up and down.
You gotta love the optional extras
I picked up my 4door in great stock condition for $10500 with lots of rego left.
If you want my advice buy your car through a private sale, know what your doing, use a good real mechanic to check everything, and do a COMPERSSION check.
Ahh i just noticed that, look at my rear window cause i was peeling off that sunshade mesh applied to the window. Saw an imprint in the carpet of some sort of box which sat between the two rear speakers. Was wondering what was there. My rear window is covered with small specs of glue from the mesh which a peeled off. Only way ive managed to remove some is scratch with nails as a regular cloth doesnt do much. Anyone have a quick method to remove all this gunk off the window?
Thanks
Might try eucalyptus oil as i dont want whole car smelling like petrol from the inside.
Does the r32 gtr spoiler fit into the same holes as the stock r32 gtst wing?
Reading around, to fix holes it will cost $300, rather put a gtst/gtr spoiler instead :(
Also how much would it cost to respray spoiler to black?
Thanks
Where are all you guys getting all this info from?? The Vicroads Modification guide has no maximum wheel diameter rules in it at all. I still stick by my comment of being allowed rims with any diameter, as long as the wheel and tyre diameter doesnt change by more than 15%...
https://www.vicroads.vic.gov.au/vrpdf/rdsafe/VSI%208.pdf
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
