I have to clear out some stuff from the garage so I have:
"Box of 6" Eagle One Ultra Glaze Polish as seen here:
$25 per box if picked up - Melbourne.
$35 delivered australia wide.
I have about 10 boxes with 6 bottles in each.
48 piece air tool kits - chrome vanadium bits and all tools are alloy. Not sure where they are made but warnings are in italian and spanish - all are brand new! - 20 available
Each kit contains
1x 1/2" Air impact wrench
1x 6" D.A.Sander
1x 6mm Air die grinder
1x 150 Air hammer
1x 3/8" Air drill(rev)
1x 4mm Hex key wrench
1x Oill pot
10x 1/2" Sockets 9 - 27mm
1x 1/2" Dr5" extension bar
1x 6" Pad\
2x Hand Wrenchs
5x 6mm Mounted grinding stones
5x 3mm Mounted grinding stones
1x Collet chuck
1x Collet retainer
4x 125mm Round shank chisels
1x Chuck key
2x 50mm Bits 4,6
2x 50mm Bits 2,3
5x Nipple
1x Blow mold case
$125 pickup from Melbourne
$150 delivered.
or call paul on 0402383944 for any info.
    • Like a big hood scoop, and massive whiney boy supercharger? Think he'll sell it to me at my offer above? I could probably get it to $75 if he needs a little more convincing 😛
    • Salut Frederick. Belle 370z. Welcome to SAU!
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
