Hey guys I’m thinking about running a shot of Nos on My R33 Skyline.
I don’t know how the Engine will react to this so I’m just asking around if anyone has done it or if they can give me some advice.
The only modification that’s car done to my car is:
• FMIC
• 3’’ Turbo back Exhaust with High Flow cat
• Standard turbo High flowed
• Heavy duty clutch (extreme)
• Bosh 044 pump
At 7psi she pushed 182kw@the wheels on Dr drifts dyno.
I was thinking of a dry system and a 70hp shot of nos.
I dont want to do much engine work, i was told that the engine is good enough for around 300kw @ the wheels??
I don’t know much about NOS systems. So any help will be grateful.
Thank you very much:D
Edited by Dush
https://www.sau.com.au/forums/topic/129203-rb25det-with-nos/
It would be a cool thing to have in your interior so you can 'hit the NOS'. But seriously maybe a dual stage boost controller set between stock and about 14psi will have a similar effect. Cant see the practicality of a nitrous system especially the defect factor
Regardless of what people have been telling you, you can run 100 wet shot comfortably, all you need is fuel pump upgrade which you already have, Aftermarket engine management e.g PFC and the Kit. with the correct tune the car will make around 250rwkw and be capable of mid 11sec passes. This is not a toy for the street though. and we will soon see how heavy duty your clutch is. You can buy wet kits starting from $990 which include everything to get started, just need to add bottle warmer $ pressure guage to tune. Dry systems require the fuel to be added through the injector rail and sometimes require the upgrade of injectors. is not something you can fine tune urself unless you have extensive knowledge of tuning with PFC or ECU you decide to use. People on this forum have been running the bottle for a couple of seasons know with no engine failures. By far the best bang for your buck.
• FMIC
• 3’’ Turbo back Exhaust with High Flow car
• Bosh 044 pump
As long as you are able to adjust ignition timing with it, then yes it would work. need to pull total timing out when the gas is on. A/F you adjust with fuel and bottle pressure & different pill sizes. In saying that if you are looking to get maximum performance out of your car a stand alone may be necessary as to get full potential out of the tune before you add the gas. Can run 1 bar of boost and 100 shot on standard engine with standard injectors etc.
so to run a 50-70hp shot of gas you would need a Stand alone computer and a piggy back wouldnt work???????????????
Edited by BezerkR32
Get the car tuned first, then pull around 4deg timing total out. use pills recommended in kit. these are on the fat side. start from there. Start with 900psi bottle pressure. will need a Air fuel meter to do this. best done on track. Not familiar with too many shops in Melbourne as i am from wollongong but buy kit from Barney at VPW and he should be able to advise you on who too see.
Thankx for your help guys.. i get a ECU first befor i strap the bottle.. is their any good workshops in Melbourne that have extensive knowledge in tuning nos systems?
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
