Cop Trouble?
SIKLINE
 Share
:no: Well either I just have the worst luck or the police in Vic are just bored. I bought an R33 GTST S2 about 4 months ago. since then I have been stopped 8 TIMES!!! the car is dead stock apart from a pod. What is really driving me crazy is that I'm am never doing anything Wrong. Twice they have approached me in a carpark.....(can they do that?).
Today was the worst, Driving back from the city. Pulled up.... Got the once over and Left with a $120 fine. WASN'T SPEEDING, WASN'T HOONING. no points were taken. WTF
Please Guys, All you 'p'platers, please tell me, Do you get this much abuse?
What does the fine state?..... If you don't know what the fine is for why didn't you ask?
As Dark stated it's illegal for you (p-plater) to drive an R33 GTS-t, due to the power-to-weight law. So you are NOT doing "nothing wrong" as you are ALWAYS breaking the law.
You're breaking the law everytime you drive your car.
Stop complaining.
If you want to whinge about the cops, head on over to NissanSilvia.com
Summed up my thoughts exactly.
Thread closed. If you wish to debate the fact your driving a car illegally and feel hard done by because you are driving illegally and being pinned for it.
Call VicRoads
cheers
Yeah bit in the moment last night. Won't cry anymore.... take everything back and suppose ill see ya on the street in something cool like a swift. lol thanks for the response though (to COP TROUBLE)
see ya
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
