Just Jap now stocks a wide range of products from Trust/Greddy and we are pleased to bring you more great deals, this time on Trust's 60mm Dual A-Pillar Gauge Pods for Nissan Skyline R33 GTS-T, as well as S13.
Designed for a clean, factory appearance when fitted, these pods will suit 60mm gauges and fasten neatly onto your A-Pillar.
Each gauge holder includes the clips/plugs and associated items required for fitting
Just Jap will not be beaten on price and we pride ourselves on providing the very best service and very best prices to our customers.
We have these in stock now, ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
TRUST 60MM DUAL GAUGE POD
PURCHASE YOUR TRUST DUAL GAUGE POD NOW FOR JUST $145
So how can I place my order?
The answer is simple!
Visit http://www.justjap.com/parts_ngauges.htm and purchase your gauge holder online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
would u hav 1 for r32?
Hi mate, we dont have them for R32 in stock, but ordering isnt a problem.
Cheers,
Steve
  • 1 month later...
We how have another 20 or so of these dual A-Pillar holders from Trust to suit R33 i& S13 n stock.
Thanks for all the orders guys.
Steve
  • 2 months later...
hey im after one of these 60mm pillars, all gauges should fit, like the apexi 60mm el series?. any other way to pay instead of paypal or c/c, any direct debit i could do .. thanx
Hi mate, thanks for your enquiry.
Payment by direct deposit is available - If you would like to proceed with an order please pm me and I will respond with all the information you require :)
Regarding the gauge fit, any 60mm gauge should be fine.
Cheers,
Steve
hey Steve
just wondering if you need to order in a dual pod to suit my 4 door 32, or are they the same as coupes?
cheers
Adam
Hi Adam, we only have them to suit HCR32 2 Door im afraid.
The 2 door and 4 door are different.
Cheers,
Steve
    • What did the rear look like before repaint from the "rich idle"?
    • I know that smallbox is not great but as i said it will be for a limited time and iam not going to get crazy. But thanks...i just want to know if i can use that clutch and not have "problems"
    • No no. The Audi boost controller was made from a Norgren (or equivalent) 1/4" pneumatics pressure regulator, a similar (looking) relief valve (to create the "gated" function to keep the boost off the actuator until wanted) and a check valve plumbed in parallel with those two, to relieve the boost back out of the wastegate line after the boost event was over. It was the inclusion of that check valve, used sort of "backwards" as a relief valve, that was the stroke of genius that made the rest of it work nice. The only reason I stoped using it was because it was like any other manual/pneumatic boost controller - it's settings changed from season to season. The Profec is much more consistent winter to summer.
    • A couple of months of gentle driving will be fine. There is a risk that you will kill it. A heavy workout will probably kill 3rd gear. Continued use will wreck the input shaft bearing.
    • That's because R34 RB25DET is a pull clutch gearbox. I have that clutch, behind 25Neo, in front of R33 gearbox. I have brand new R34 turbo gearbox, in a box (cardboard) in the shed right now, and it will be getting used with the same engine and clutch, because I also have, in a much smaller box next to it, the front plate to convert the new box to push clutch.
