How mcuh power does your car have?
5th is just another gear. obviously you're not going to use it at 20km/hr. you won't use 4th or 3rd either at that speed. that doesn't mean that the box isn't strong.
This is what I do when driving normally:
1st 0km/h
2nd never use below 20
3rd never use below 40
4th never use below 60
5th never use below 80.
It has worked for me. Trying to use these gears at anylower speed just loads the engine right up and i can hear the bearings straining.
My car has 480 rwhp.
I have heard that VL turbo gearboxes (very similar to r33 gearboxes) have weak 5th gears and when they have any sort of power put through them something fails and they become noisy and the shifter vibrates when in 5th.
I was just wondering if anyone could shed any light on this?
nope. all gears are the same strength.
just use it.
The only gear that people have trouble with, and you'd have trouble doing this in any car, including a supra box, is when drag racing, flatshifting and hamfisting the stick into third. This only seems to be a problem on the gtrs though, most likely because of the awd and big power.
Not just GTRs. When power is elevated more often than not first and second gears are subject to some wheelspin.
From third onwards when full traction is available the drivetrain has to deal with the full brunt of the torque being delivered.
In theory the clutch should be the fuse in the driveline and never be rated higher than anything behind it. But in practise most people have no problems putting in clutches rated higher than the driveline they are designed to protect hence gearbox, tailshaft, diff,axle breakages.
From what others have said, it is the hamfisting of third when dragging.
You're trying to shift as mcuh as possible and slam it into third at near wot. Apparently it is this mashing of third that kills it.
Just shifting easily into third then planting it, even with moderate power hasn't really killed any boxes on this forum to my knowledge (rb20 boxes excluded because they're like a twig).
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
