Just Jap Sydney is proud to offer Skylines Australia forum members the best deals on the latest high performance parts including our new TRUST & JJR Adjustable Cam Gear & Clear Timing Cover bundle pack for Skyline GTR.
The JJR adjustable camshaft gears are designed with maximum strength in mind, and are manufactured from high grade T-6 aluminium alloy, with hard anodizing for long lasting durability under demanding conditions. Adding these adjustable gears, particularly when used with factory camshafts, can provide proven results with increased power, response and overall drivability.
JJR Cam Gears include a 12 month warranty, backed by Just Japs unmatched after sales support.
Also included, the ever popular TRUST clear timing cover which not only enhances the look of your engine bay, but provides you with the ability to quickly and easily examine your cam gear settings without the need to remove your timing cover completely.
Looking for the very best in performance parts at the unbeatable prices you expect? Look no further.
We have a large number of these in stock right now ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PURCHASE YOUR BUNDLE NOW FOR ONLY $399 + DELIVERY!
So how can you place your order?
The answer is simple!
Visit www.justjap.com/parts_nengine.htm and purchase your bundle online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact our sales team if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
Hey Steve,
Do u have/make these for the RB20DET?
I know that u have the gears, but what about the covers?
im also interested for rb20det cover :)
Hi guys, Trust only makes the clear timing covers for RB26 - I would imagine that fitting them to an RB20 would require significant modification if it were possible.
Cheers,
Steve
  • 3 weeks later...
Heaps of stock available.
Many more Trust products also in stock
Cheers,
Steve
Hi Steve,
Do u have/can u get Trust Intake Manifolds for the RB20DET?
Regards,
Sherwin
Hi Steve,
Regards,
Sherwin
Hi Sherwin, we can only supply the Trust intake plenum for RB25DET and RB26DETT at this stage im afraid.
We can however source Plazmaman plenum kits for RB20/RB25
Regards,
Steve
Hi mate, how much would it be if i only want a pair of Trust cam gears?? i have a clear cover...
Hi Frank, do you mean our JJR Adjustable Cam Gears or Trust Cam Gears?
We can do our JJR gears for $160 each
Cheers,
Steve
I thought it was Trust....
how much would Trust ones be?cheers
At the moment, we have only JJR, OS Giken and Tomei Cam Gears for RB series engines in stock.
The JJR Cam Gears are $160 each, the OS Giken Cam Gears come as a pair for $399, and the Tomei Cam Gears retail at $285 each.
We can order the Trust gears for you, the price would be similar to the Tomei but the JJR and OS Giken options present much better value for money.
Regards,
Steve
Hi Steve,
Do you know whether the JJR gears fit on a CA18DET?? if not, do you have any to suit a CA18DET??
Cheers
Hayden
Hi Hayden,
The RB and CA cam gears are different.
We have Tomei adjustable cam gears available for CA18 however they are significantly more expensive at around $285 each.
Regards,
Steve
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
