Now that I am at uni, I do a lot of short trips with the car stone cold. I live 5km's away from campus. Hell I’m only using $30 of petrol every week including weekends. I used to spend close to $90. Mind you I’m not on $1160p/f clear any more, instead a measly $310p/f. :(
Now for the Diagnosis.
When the car is cold:
- On the initial start the idle would splutter and struggle for 1/2 a sec then the revs would rise to 1100rpm;
- and when idling, if you attempt to press the accelerator ever so slightly the rev's will slightly raise like I was twisting its arm but the motor will sound strange and splutter;
- cruising down the road attempting to sit on a certain speed the car HAD :P a slight flat spot. The sound difference can be heard through the CAI. Accelerate a little more and it takes off.
These problems were still evident once the car was warm however they were hardly noticeable. The start still spluttered a little but nothing like when cold.
In first gear attempting to idle around a car park you could notice a notchy on off feeling with the accelerator. It made life a real pain in the arse.
ANYWAY... I've always suspected the TPS.
I've finally got so sick of hearing driveline slack when looking for a car park due to the notchy on off accelerator and all of the above hassles.
So out comes the screw driver ;). I loosened off the two screws and got the feel of how the TPS operated.
The TPS was set roughly to around 9/10th's clockwise to its total range of movement. When setting it fully clockwise, it caused the car to have an extreme flat spot on light throttle, it basically amplified the problem. I started to GRIN. Get the butterfly’s etc etc...
I then turned it anti-clockwise until I heard the rev's raise then backed it off with a slight touch of the screw driver. Tightened her up and took her for a test drive.
First thing I noticed is that on off throttle transition was extremely smooth BUT... when gearing down it felt like an AUTO and the exhaust would ever so slightly pop or gurgle if you like.
I pulled over and noticed that the revs were idling a little high so I must have accidentally knocked the TPS ever so slightly when tightening up the screws.
I dropped it back again until the idle dropped.
The TPS is now set to roughly 7/10ths.
NOW... No more horrid on off throttle transition in gears and it also starts perfectly (no splutter), and the best part the cold driving or cruising flat spot is now totally gone.
The TPS is extremely sensitive to the slightest movement.
It may be a co-incidence or possible it may have just patched up an underlying problem.
Any one got any comments or experience with the TPS?
:alien: ;)
  • Replies 42
Do you get a slight kind of flat spot for the first km or so?!?!?
I don't really warm up I just drive it really easy.. 3000rpm max rev's with light throttle. Well It gets maybe 30seconds or so while saying cya to the fiancee and putting on the seat belt.
lol... Just looked at the Avtar.. Took me a while..
I've just been out enjoying the last of my tyres.. They are getting low and very very slippery.. Powering on in second causes instant wheel spin snakeys over the road.... :burnout: :burnout:
i had a problem with my car idleing to high so i pulled the TPS off... looked at it... put it back on and it started idleing perfectly!
i do have a big flat spot just before it comes on boost when its cold though, and the 1st set of lights i come to i usally have to give it a little poke to stop it from stalling but once its warmed up its fine.
im having problems with my TPS too, although different to your cases
i dont get any flat spots not idle problems but on my handcontroller for the Wolf the TPS sensor reads all sorts of numbers when i have my foot off the throttle
sometimes at WOT, sometimes halfway, but this doesnt effect the engine at all which baffles me because the wolf uses TPS/Load/etc to determin ignition/fuel/etc
seems to reset to 0 TPS when u rest your foot on the accelerator, but once u let all of it go, it goes erratic
im thinking dodgy earth? connections seem fine though
i dont know
To test that it isn't adjusted to much to the left (Anti-Clockwise) sit in 3rd down a hill and the motor should sound like its getting no petrol.. Hence no gurgling.. just an anoying bwaaaaaaaaaa.
If you get what I mean.
I used to also got a lot of poping and some times backfiring between gear changes on light acceleration.
This has also now dissapeared.. :D
woutl this problem also apply to other nissans etc?
guy i seriously think that we shoudl creat a site or page with all the problems that you guys solve instead of pointless hours searching and asking questions when it has been solved before what ya think +)
iam willing to set up a site =) and do i t=)
I had the same problem with my VL Commodore.
Not sure if it was the TPS or if they have one however.
That used to start perfectly though. But it did have the flat spot on the tip of the accelerator. It was slightly different. But basically felt the same.
Don't know if this helps, but I used to have a Nissan Bluebird with a Z18 Turbo and Autronic Management. Tuning was performed with a laptop and on this you could see what all the sensors were reading as well as seeing what the computer was reading for throttle position from the TPS. It would use throttle position to assess load and then the fuel and timing map was made up by plotting load against rpm.
In other words, if your Throttle Position Switch is not reading 0 where your butterfly is closed or at idle pos, your mixtures and timing are quite likely wrong for that condition, then when you open halp throttle, your TPS tells the comp you're 3/4 throttle and again your mixtures are sell out. This is what causes your missing and erratic leading and trailing throttle. I used to stick the PC onto the Auronic once a month to recalibrate the TPS, never knew why it kept going out but it did.
Hope that helps.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
