Selling my R32 to make way for my next car.
the car has damper adjustable suspension fitted. Also have GTR front bar. front mount intercooler with custom stainless pipe work . Windows are tinted it's called 20% extra it's pretty dark but not 5%. Comes with (QLD) JAP32 number plates
$9000 ono
pm me if your interested or sms me on 0424623426 sms me first and say that your interested in the car before you call or i prolly won't answer.
ps. scroll down to the bottom of the page for more pictures car has been painted since ignore the close ups of the paint work. here are the new pics painted and gtr bar fitted.
https://www.sau.com.au/forums/topic/129232-sold/
  • 2 months later...
Need to post some Answers mate
Killometer's: ?
Manual or Automatic transmission: ?
Engine Type: RB20DET?
Complianced: ?
Road Worth Certificate: ?
Registration: ?
Reason to sell: ?
Crash History: ?
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2625346
as you can see in the picture it has personlised plates on it so it's been complied and registered. it's 5 speed manual. RB20DET with custom stainless pipe work for the fmic. i'm on the gold coast. selling becasue i am buying an R34 would like to keep this car too but can't afford to. drives smooth. no crashes as far as i can tell. has about 110 000km's.
Edited by jap32
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2630458
Hmm, mate,i've added your car to what im interested in, i've just gotta sell me car, and i'd be on my way. lol.
If you know anyone :)http://www.skylinesaustralia.com/forums/in...howtopic=141268
Edited by MATTYBE
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2631112
where about are you located im going to aska friend of mine to go and have a look for me, i will bve in contact with you soon, 6500 with kit fitted and sprayed? ill talk to you about it over the phone any way just need a location for the moment so i can suss out someone to go and have a look for me.
thanks
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2697391
  • 3 weeks later...
  • 4 weeks later...
i have just spent $1000 on paint work and fitted the gtr front bar so i'm asking $9000 ono post pics today. scroll to top of page for latest pictures
Edited by jap32
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2798048
hey mate, so all the whole body has been gone over n removed those rust spots? was the whole body rubbed back n sprayed or just a patch up job? also that looks like a hell of alot of blow-by coming out !! have you had compression test n that done?
thanks
Edited by 2gceffy
https://www.sau.com.au/forums/topic/129232-sold/#findComment-2813085
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
