I wanted to see if anyone is interested in a Club War Dyno Day.I wanted to see if people from SAU,Pichka,Obsessive,CALAISTURBO ETC
wanted to come.I want to pre book Entries so i can organise trophies ETC.I will organise a BBQ AND DRINKS and also have some off the big cars on EXHIBITION.Such as Mark Hayes,Simon Kryger ETC
https://www.sau.com.au/forums/topic/129237-dyno-day/
it will be
$50 including Food and drinks
there will be trophies and
ill have my car there too
just need to comfirm numbers as im organising trophies and food
i want to get a few skylines there this time as last time i didnt have any but my own
actually there was one claiming he was making 400 kws and when i asked if he wanted to put it on he claimed ohh its still running in
hahahahahah
doesnt matter
its gonna be a fun day
prob organise a cruise afterwards as well
https://www.sau.com.au/forums/topic/129237-dyno-day/#findComment-2392736
im going to make catergorys to suit whos comming
just depending on whos comming
there will be
Rotary NA
Rotary High Performance
4 cylinder standard motor NA
4 cylinder standard motor Forced induction
4 cylinder High performance NA
4 cylinder High performance Forced Induction
6 cylinder standard motor NA
6 cylinder standard motor Forced induction
6 cylinder High performance NA
6 cylinder High performance Forced Induction
V8 High Performance NA
V8 High Peformance Forced induction
If i dont get any pre entries to any off those classes i wont have that class running on the day.If they arrive on the day i willl organise trophies but once again I want to pre book all cars till i get around 25 and then ill setup a exact date.The reason for this is im allowing the First bookers to give me a date when they will be ready so far it will be around late september.
There will also be a Show and Shine Happening on the day as well as a BBQ for everyone there.There will be some exhibition cars there as well for the Crowd
Edited by MR331307
https://www.sau.com.au/forums/topic/129237-dyno-day/#findComment-2396074
4 people have weddings so far that weekend
Wild 1 Motorsport is in wollongong
Carnt miss it near BHP
The date will be either the 24th of september or the 8th of october
as a couple people have a wedding on the 1st of october
has anyone got any problems with any of these dates
please let me know
Edited by MR331307
https://www.sau.com.au/forums/topic/129237-dyno-day/#findComment-2399875
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
