  • 1 year later...
  • Replies 78
It's been a long time since this thread was around and since there are so many newbies in the Stagea Section I thought it was about time to resurrect it so you can add to the list and reveal all about the mystery surrounding your sign in names.
For an explanantion on what the thread is about, go the original post on page 1.
*kicks things off*
Mine is actually my nickname given to me by my (then) 5 year old daughter. She used to be called "little chicken" as well as all the other usual baby names, but one day I was changing a nappy and called her "Stinky Chicken" and it just sort of stuck. Years later she decided that I should be called Stinky Rooster.
So, to all those that asked, it is NOT because I have extra fragrant genitailia......
As a keen jetskier and having destroyed many jetski's in my day I was looking for a new name for online gaming and just happened to be looking out into the backyard at a recently destroyed Seadoo XP Limited(Bit tipsy at the time if I am recalling the story right).
Anyway didn't mind it, people remember it and now I'm used to it.
this is an aoursome thread glad to see we can keep it alive.
Now my nuser name. i wanted somthing thast unique and i use petrolfix all across the net.
it came about cos me and my step brother (at the time, god rest his soul) had dreams of opeaning a performance shop we where coming up with names to call it, piston-perrfection was the one we decided on at the time but our second coice was petrolfix.
Petrolfix itself came about as a we both where driven by cars. all ways watching motor sport, ralling cars reading magazines, unless it had a motor i'm not interested. I have been a petrolhead all my life and as i get older the addiction gets worse. The same way a drug addict needs a fix I need a fix for my thurst for petrol powerd machines
(just like my signiture reads)
Helloooo Springfield
My name is Mister E
It comes from the Band the Eels the lead singer calls himself MR. E and I like the band so I blantantly stole His name.
I also like how when you say it quickly its like Mystery....at least it does in my mind. I'm not going to sit here at my desk at work and say mystery over and over again.
I dont think i should mention how i got mine or what it means but i got it a few years ago :)
I am apparently wild and cat is um..................... :rofl: well use your imaginations and it will come to you :D
Use that nick in everything i do and am even going to get the plates for the stag with that :P
That is the best reply in this thread thus far. :D
Xmetal is something i've been using now since 1997, It was an object of my desires to start with but I grew to use it on everything I do, it's even my business name now for my photography. :) (events, weddings, automotive) *shameless plug* :P
My nickname is actually my nickname my mates gave me since year 12. The Big is because i'm tall. The Dirty part of my nickname is from playing video games (was always the one with sneaky move or shot on someone) and Jase is my name. The nickname has stuck for a long time
There you have it
Edited by BigDirtyJase
Well, the day I was born, the moon was in its 3rd phase, and Jupiter was aligned with Mercury. It was exactly 17 weeks since the last Solar eclipse, and a white dove had been seen overhead for the three days prior to that of my birth....
I was always known for being blatantly obvious. Still am. AlthougI go as Mickeyb on most other sites.
Man, am I boring...
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
