hks super sequentials, they flutter/wooosh/whistle and all the rest, depending on how u release the throttle..
with mine, when i spool up the turbo and build up heaps of pressure in the intake pipes and release the throttle quickly it makes a woooosh sound, if i release it slowly it makes the fluttering sounds..
Edited by MKDR33
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2391193
there is a massive thread covering this in forced induction (i think its in there) all about the sound BOV make. There is also a web site ffs that lets you here them. Agreed with hks super sequentials
If your putting it on a stock skyline DONT your car will more then likely stall when come to a stop, also cause other issues that are covered in lots of threads.
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2391200
Thats gold! LOL
I dont think that you need to worry about finding a BOV that "flutters" because just about all BOV's are very similar in design...
The noise that you want is made according to how your intake system is set up ie:
*whether you have front mount intercooler or not,
*whether your BOV is plumb back or straight to atmosphere,
*whether you have a pod filter or airbox,
*whether your boost is turned up or not...
There are many different things to factor in when playing around with the inlet... And as said in previous posts, you might have alot of trouble with your mixtures (air/fuel) if you put the wrong BOV on without doing anything else to the car first (like a programable ECU or Air fuel controller)...
BOV's basically just make different noises according to how tight the spring in them is set to.
Happy hunting though :)
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2392799
hmmm.. if this was the case, wouldnt the car stall? as the turbine will be forced to stop spinning and the exhaust will be returned back in the engine/trapped in the exhaust manifold, causing the engine to stall?
ive revved my car from the throttle body, looking at my bov as it releases air, and when it flutteres, i noticed the spring on my bov bouncing open/shut..
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2392800
The flutter is caused by the air thats in the inlet tract coming back out the airfilter when the throttle body is closed (when you jump off the throttle). Its called thrust reversion and another commonly associated word is thrust reversion damage (a turbo spinning at 100,000+rpm and suddenly has air forcing its way back through it the wrong way).
Its easy as pie to make your car flutter... remove your stock BOV and make sure you have a pod filter. With aftermarket bovs they reason they flutter is the bov is either not venting at all or only partially venting and the rest of the air is going back out the intake.
On a stock ECU it can cause all kinds of problems as the air thats expected to go into the engine doesnt make it in but the fuel does causing it to partially flood itself etc.
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2394232
Simplest way to get some flutterin'
1) Put on a pod filter (if you haven't already got one)
2) Remove your standard BOV and make a plate up to block it off
3) Crank up the boost to say 10PSI
4) With a bit of practice, you should be able to hold flutters for up to 5seconds!!!
Happy flutterin'
DISCLAIMER:
1) Your car may/will stall as the air will be forced back through the turbo and back where it came from; your AFM will go insane hence causing a sudden "drop" in RPM and stalling. Even does it on an auto!
2) Your turbo may/will die - If I spun you 10,000rpm one direction, then hit you in the opposite direction with a baseball bat, you'd die too :D
Stan
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2394274
my does it non stop, for those of you that have been in my car (polishstorm, Nick, andrew anyone else) i have the apexi duel chamber and a pod. Mind you the turbo is being replaced as we speak (by me lol) anyone want to buy a gcg highflow for 1700 so i can buy a gt30 or gt35.
https://www.sau.com.au/forums/topic/129271-bov/#findComment-2406223
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
