POLISHED SIMMONS FR18s
These wheels are in awesome condition and have near new rubber (90%) on the rears (265/35) - not so good on the fronts (235/40) because of a dodgy wheel alignment they have uneven wear.
Fronts are 8.5" wide, Offset 33mm and rears are 9.5" wide, Offset 35mm. PCD 114.3
Tyres are Falken ZE 326's.
These rims will fit AU-BA Falcons (may need spacers for Brembos), and before the GT they were on a S14 so they will definately fit them as well as S15. They should fit Skylines and other 5 stud Nissans with no troubles.
Postage can be arranged and I'd say would be around $140 for courier to the eastern states, or pick up is available. They are located in Canberra.
Asking around $1,800 negotiable.
Email Damien: d.lewis at paragonprint.com.au
or send me a PM
https://www.sau.com.au/forums/topic/129274-polished-simmons-fr18s-sold/
hey,
no sorry - have already sold them for $1800 on ebay, but if that falls through I have had another offer for the full price as well, thanks for the offer though :D
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
