Story:
So a friend of mine was junking his fairlady in the stall next to me at the hobby shop and since i had just drifted into a curb on the touge the other day i was in need of a sway-bar. so i thought id try and amazingly it fit with very small modification. im sure most of you know about this mod but since i didnt see this in "how to" i thought wtf cause it saved me $180.
How to:
Remove Torsein Rods
Then take the Z32 brackets and drill the circular holes to fit the stock R32 bolts.
Refitting the bar to the car is a bit of a bitch but it can be done trust me. there are two mounting points on each bracket, a bolt and a nut (hole and slot), i recommend installing the bolt first then the nut and maybe using a jack to hold the bar seccure to the car when starting the bolts.
Then bolt the stock endlinks up like normal. yes they fit fine.
new sway bar diameter 26.5mm!
notice floor jack used for assisting in starting the bolts.
it may look lower than usual but its not. look at how low my car is, it still doesnt hit anything.
:whistling:Enjoy! :3some:
Edited by 4DoorWhore
It sits lower than the sump.. Looks bodgy as.
assuming bodgy means the same as ghetto. i assure you its not.. but thats your opinion...
ive been driving with it for about 2 weeks now and im very happy, not only was it free to change, but it works great and makes a huge difference.
but if your worried about looks you can go spend $250 or whatever for a aftermarket sway, up to you...
Update:
i just changed out my stock endlink and mount bushings for polyurethane, and the front end is solid, i love it!!
im also running, Tein coilovers with 12k front and 10k rear springs, polyurethane endlinks front and back, adjustable camber arms, a nismo 2 way, and a few other non-drivetrain/suspension goodies. only had the car for 2 months so im still just starting.
long story short, nothing bodgy about this upgrade...
It is when you consider where its meant to sit...
You do realise if you have an accident your insurance company will take one look at it and not cover you.. Especially with such a modification as suspension. Its clearly not designed for the application.
I'm all for cost effective modifications but this one... This is something you definitely don't want to be doing here in AUS.
I suppose its good for something... a sump guard :S
Aftermarket 'adjustable' sway bar is $190.
well yeah if you think about it in leagalities. but then insurance prolly wouldnt cover anything else on my car either. but then thats not the case in japan.
but honestly i doubt insurance can even tell the difference between the two bars.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
