Hi peeps,
Need some info on this before I head off to a muffler store. I have a 3inch (i think its cat back) exhaust with a cannon tip muffler which all came with the car direct from japan. Trouble is that under some heavy foot acceleration, the exhaust gives out this loud nasty pop when the gears change. I dont want to loose the 3 inch pipe work but the sound has really got to me. Anyone else with this problem? what exhaust do you guys have on your cars?
My wifes RS4 does the same thing. I think they over fuel a bit on lift off and hence the pop. My 260RS does the same thing with the standard exhaust (she does flames though, which is cool). That is being changed soon. I wouldnt worry too much about it,
Cheers,
Ken
Hi peeps,
Sounds like the wastegate, but mine is more of a brrrt sound than a pop, mine is 3" turbo back.
Mine pops on overrun, and quite regularly too. Mine has the standard ECU, but it's been converted to manual, so I can kinda induce the popping at will with some heel-and-toe or throttle stabs on downshifts.
Dunno if it shoots flames, but I'd like to find out. Might either get someone trusted to drive it one day as I follow, or get someone to follow me...
Nope, ONLY myself and the wife drive it.
The only other time I have let someone else drive it was one of my best freinds when I was married, and even then I wasnt happy abou tit, but the wife insisted that we rode in the back, <sighs> so yeah.
No I do not like the idea of someone else driving my car, it is hard enough letting the wife bloody drive it.......... :D
Hei SKA so what you are saying id you value the car more than your wife?
:( AHAHAHH!!!!
Well to tell you the truth though i dont like people driving my car as well.
i LOVE getting driven by in my car
nothing like hearing YOUR car SUCK, FLUTTER and ROAR past :(
Then you think....so thats what it sounds like when i boost off in front of someone in a "fast" car, muahhaah
I got told my car sounds like "someone roaring and ripping their throat open at the same time". I was like, oooooo, then yeh, it does :D
Well i run the bog standard factory ECU so can't really say if im running lean or rich....good enuff cause to get a stoich meter installed. anywayz if the car runs rich on the standard ecu ...does that mean we can get away with using 91 ron pulp?
and just side tracking on the issue, how much boost can I run on the factory ecu before the injectors max out, the fuel pump suffers a heart attack or the MAF goes crazy <<whichever comes first
Mine is a stocker with 3" cat back. It always has a nice burble on back off with the odd snap crackle and pop up the top, after hard acceleration.
Exit is very sooty, dont know if it flames. Got to get the DFA finished and fitted.
hey fcruz3r, check your plugs and buy new ones and gap them at 0.8 this shoulf fix your problem reset the computer and put BP ultimate ot shell optimax in and it should be as good as new and wit the pop in between gear changes this is normal as long as its only one missfire
dont you guys let other people drive your cars?
not a chance in hell, ive already had one of my cars written off by a mate and i'll be damned if im gonna let anyone drive my car again. not even my girlfriend.
the other day my dad moved my car from out of his workshop to the parking bay (about 10 metres) and put the front bar into the gutter.....NOT HAPPY JAN!
The Autech front bars are a bitch, they sit very low (aftermarket sus doesnt help) and stick out a mile. Mines been off once for painting and is just about due again!
Thanks for the tip QIKEXT. Yea currently its just a single loud pop between gear shifts...must be just an RB thing. I'll get the new plugs anyway ...do you know the exact code number/make for the oem plugs? what about resetting the ecu..how is that done...is that like disconnecting the battery terminals for a couple of minutes before putting them back on?
I thought to reset the stock ecu, dissconnect battery, pump the brakes to discharge any capacitors still holding charge through the brake lights, reconnect battery.
But I still fail to see what that actually accomplishes, I mean it doesnt store any data, does it?
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
