  • Replies 58
It wasn't that difficult, but then again it's a bit of a half-assed job... Here's how I did it and prolly isn't the best way. Wasn't expensive though.
You need a clear panel for this
[*]get the thing off (4 nuts)
[*]remove any silver paint from letters so they are clear
[*]cut the back out in the shape of a letter box (you'll never get it open as it's sealed with goo, grrrrrrrr!)
[*]get some translucent red self adhesive vinyl and stick to inside of panel (mine needed 2 thicknesses to get the colour right) - £free
[*]clean it well and carefully mask letters and black bits (masking the letters took a razor sharp knife and a lot of time)
[*]get (right colour) spray paint and plastic primer - £12
[*]prime, spray to a good thickness
[*]get a neon tube, mine's for a PC case but is a bit short, and fix inside - I used a hot-glue gun near the ends. - £13
[*]test
[*]seal up with whatever you like
[*]tag transformer wires onto tail light circuit
[*]fix it back on
[*]connect up
[*]grin! - £priceless!
[/list=1]
Hardest bits were masking the letters and getting the right colour paint - the QM1 I had mixed was no where near the QM1 the car's sprayed in (apparently there are at least 2 QM1s...).
Cost just over 25 quid ($65 ish). Bargain.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-254975
for r32's this light was a factory option offered by nissan. in the r32 factory optional parts catalogue it was called the "rear finisher" and was sold under the following codes according to body colour.
5NG03~5NG07,5NG09,5NG10
the price at the time was 33,300 yen. i went to tokyo nissan last week to ask for one for my friend. but they ceased production quite a while ago in 1995.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-277086
guys.... i just got pulled up by the coppers. "you arent allowed to have allowed to have any blue lights coming from your car. (its green) the only people allowed to have blue lights are police cars" "it came with the car!" "remove it"
i was lucky to get away with it, because the car was just imported. the fine is $75 and one point.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-318082
AtomicBomberMan
what state are you in, im in WA and the new rule here is that there is not allowed to be anything like on the bonet, but you can have any colour underglow you want aslong as the globes themselve are not visable. So the glow is fine. I had blue LED windscreen washers to and they are illegal because they are visable but underneath fine...Weird!!!!!!
Taking pics tonite so ill have them up on sunday for you guys to check out
cya
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-320003
G'day Moschops
Can I ask, could you explain the following steps. I'm having a lil trouble trying it
How'd you remove it? scratch it off?
How'd you cut it? looks kinda fragile thats all.
Hmmm, any advice on where I can get this from?
May I ask, what black bits are you referring to? I presume you simply used that white marksing tape is that right?
Please advise as I reckon your car looks awesome. Thanks heaps in advance.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-321674
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
