  • Replies 58
  • 3 months later...
ok here is my theory.... remove the plastic skyline part and cut out the skyline lettering with a hot knife... then lie it down on some grease proof paper and fill the cutouts with clear resin... wait for that to dry and then mount a fluro tube behind it... you can then use any color celephane you like to adjust the color...
https://www.sau.com.au/forums/topic/12932-has-anyone/page/3/#findComment-507341
Originally posted by ZERO
how do u exactly take out the plastic thing?
remove the black trim that sits over the boot lip (with the square cut out of the centre for the boot latch to click into) there should be about 5 clips holding this in, just yank upwards...
then you remove the grey trim boot lining thats underneath it, this will have a crap load of clips in it - just unscrew the centre bits of the clips with a phillips and pop the outer rims out...
there should be 4 bolts holding it in, 2 at either end, youll need a long ratchet to get in there... oh and there is also a little white clip in the centre of the panel, you'll need to use a flathead screwdriver to get that out, just press the little tabs in and the pull the panel out...
hope that makes sense, if not let me know and ill take some happy snaps for ya!
https://www.sau.com.au/forums/topic/12932-has-anyone/page/3/#findComment-509970
ok now go get yourself some 280+ sand paper and sand off the silver from the lettering...
then get the paint code off your VIN plate and find a place that will make the paint (2pac) up fo ya in a pressure pack... you also need a base coat and clear to go over the top...
the 2pac in a can should keep u busy for a few days, its against OH&S to supply it so your gunna have to find somewhere dodgy....
SI skyline bar... yep thats done and done!
https://www.sau.com.au/forums/topic/12932-has-anyone/page/3/#findComment-533234
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
