I know this topic has been heavily discussed before, but I couldnt help noticing that a great number of you have sydney kid suspension on your wish list of future mods....can someone please tell me what make/brand these are? adjustables or lowered springs on aftermarket shocks?
I dont know what suspension components are installed on my rs4, came lowered from japan...but currently it rides like a brick....not really ideal if you're crusing on a full stomach.
https://www.sau.com.au/forums/topic/129328-suspension-upgrade/
http://www.skylinesaustralia.com/forums/in...showtopic=53079
simple, Sydneykids specs involving Bilstein shocks and Whiteline components (springs, bushes, swaybars etc). I went without the springs (using standard) and find it a most suitable ride.
edit: to lower it or raise the suspension, SK had "notches" scrapped into the shocks, and you can adjust the height simply using circlips. pretty much they are lowered springs on aftermarket shocks
Edited by Tangles
Sorry to steal the thread but it seemed like a logical place to ask...
What colour should the bilstein rear shocks be?
The ones in pictures I've seen are yellow whereas I've had mine replaced under dealer warranty some time ago and was told they were bilsteins, yet they are black. They are definitely new though and provide a very comfortable ride.
Genuine Bilstein shocks have "BILSTEIN" machine into the shock body along with the part numbers. Thye are usually down near the lower shock mount.
:devil: cheers :down:
wouldn't cutting threads into the shock body compromise the strenght of the overall assembly?
Nope, Bilstein Skyline shocks come with circlip grooves standard, the Group Buy simply adds a few more. The shock body is designed for that purpose.
:wave: cheers :D
Edited by Sydneykid
Well seeing as though we are asking questions in here, and I dont want to muddy up the ongoing thread....
Can someone explain to me this approx 10mm rake effect... From what I can deduce if you wanted a 10mm rake effect for the nose down... wouldnt you then want the distance from the centre of the wheels to the wheel arch on the front to be 10mm less then the distance on the back wheels? I find it confusing because everywhere I am reading of this nose down rake effect and the measurement are always higher on the front and not the back...
Please help a poor confused man :wave:
Can someone explain to me this approx 10mm rake effect... From what I can deduce if you wanted a 10mm rake effect for the nose down... wouldnt you then want the distance from the centre of the wheels to the wheel arch on the front to be 10mm less then the distance on the back wheels? I find it confusing because everywhere I am reading of this nose down rake effect and the measurement are always higher on the front and not the bad...
The front and rear guards openings are not "cut" to the same height. The rear guard opening is in fact ~15 mm lower than the front guard opening.
Hence, rake is best measured at the sill (just behind the front wheels and just in front of the rear wheels), that's where the 10 mm nose down comes from.
:D cheers :(
Thanks sydneykid. I'll email you when its time to change the shockies on my car. right now i'm saving up for a FMIC and SAFC (will have to do this on the sly coz my wife has a tight grip on finances at the moment)
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
