1990 model Nissan Gtr 2pac BLACK
DRIVELINE:
Brand new Extream Super Heaveyduty 5 puk clutch (still had original nissan clutch in it)
Full re-genuine gasket set TwinTurbo side after turbo inspection
Full Redline Fluid system
Full Service history Since import
Nismo 320km Instument panel
HKS Adjustable Coil overs
HKS POD'S
Uppgraded ECU (japan)revised AFR no limiter.
Brand new Natrad Radiator
Autometer Boostguage 35psi
Climate Control Calibrated ( a must for Black car )
3inch Exhaust
Recalibrated Oilpressure Sender
COSMETIC :
Brandnew 2pac Black paint
brand new Original Carbra (black) used once
Tinting 23%
Original skyline floor mat's
Hiqual lined water proof car cover
Never been in Accident :devil: as far as detailed inspections can tell and been Inspected with a fine tooh comb as far as driveline
It has 145000kms on nismo instrument cluster
Car runs a nice 210 kilowatts on 12psi and very tight alround.
I dont really want to sell it as it took me so so long to hunt down this cleaner Example but realestate has come up
$20800 OnO
pls note that this graph was taken with a small rear turbo gasket leak as well as an original nissan slipping clutch. All has been replaced and it runs alot better than when that was taken.
Extra's Bought for the Car, theses are not included in price and would be negotiated / sold on top of asking price.
the Motec m8 was to be its Controll and Guage stystem for Boost , Nos , Traction ,Launch Control all running from a dedicated laptop hence why the car is not all Auxiliaried out!
Motec M8 808 version Fully optioned for Track Racing (includes Logging , Traction Control, Boost ,n2o Gearcut etc $2200 will only be sold with the car !!!
Brand new Turbosmart 48mm Wastegate $650
Edited by ishh
https://www.sau.com.au/forums/topic/129334-r32-gtr-black/
  • 3 weeks later...
thank's guy's
All I can say is it is the neatest one i could find and really happy with it after sorting certain small shall we say, Japenese bug's out :)
I am fairly Astonished that no one has sussed this car with its motec availability!!! $22000 for a Black A1 track enabled MOTEC ECU Godzilla...
i forgot to mention it has its own custom waterproof Car cover tooooo ;)
Edited by ishh
https://www.sau.com.au/forums/topic/129334-r32-gtr-black/#findComment-2496616
NO jeep thanks .. I got a nissan patrol now for the mud :)
My self i cant tell if the water pump has been changed and i aint taking all the stuff off to find out because it's running fantastic. I believe the timing belt would have been done at its 100,000 magor service... Some one here will know what's involved with that service as i havent studied what nissan actualy do for the 100,000 .
https://www.sau.com.au/forums/topic/129334-r32-gtr-black/#findComment-2523339
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
