A genuine front bar won't cost that much. with $3k only you would have a genuine strong front bar, that would be sufficient enough for front impact crash rating. Not a cheap fibreglass copy for $650 that might get you killed or leave you with $10k repair bill on your car, as these cheap copies are only as strong as paper in the event of an accident.
So, I'm saving for a genuine one. Maybe I'll get that $1800 genuine veilside front bar. Whole kit with side skirts shouldn't cost more than $6k. The E1 style is not bad. Looks like it's using the standard blinkers as well.
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-243608
Originally posted by GTR-80Y
I might be willing to part with mine....i've got the full C-I kit minus the flares, I also seem to have the GTR CE-I rear wing instead of the GTS C-I one. Front bar needs a bit of work tho.
GTR-B0Y, any pics of your front bar?
What do u mean the front bar needs work? is it damaged, how bad is the damage?
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-245113
are the legit ones poly eurathane or carbon fibre? if its carbon then jus go the fakes man, jus make sure the ones you get have a wire mesh underlay (othawise they jus snap and crumble)
the bomex kit i got on my old 180 was 50% aluminum 50% poly eurathane... so basically it made it look good and as solid as stock, maybe veilside do the same.
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-245858
i always thought that the strength was in the metal reinforcing bumper that your bumper skin sits on, surely the strength of your body kit doesnt matter at all aside from the fact that scrapes may damage some more than others..
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-246467
yeah in case of an accident of that proportion the chassis is the only thing tha stops you from becomign a sardine... the panels don't have much to do with it.
Getting an original helps when you get into a minor accident... (like the one I jus had where sum kant backed into my bumper) all that happens is that your paint cracks and you get a scuff mark das all... wheras if you had a fibreglass one you'd have a massive crack and you'd have to do some major patching up which costs as much as the panel.
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-246877
HEY all!! if you live in Sydney and want ANY and i mean Any bodykit, parts, body repair on ya car, mods, ANYTHING i know the place to get it done!
VISION AUTO SMASH REPAIRS
29-31 Carlotta Street
Artarmon NSW 2064
ph: 9436 1299
Ask for Jerry
These guys r soooooooooo good!! i got my Veil Side rims from them!! i would of got the body kit but dont have the money!
They can get ANY body kit you want, they can do ANY mod you want and they can repair ya car if u have crashed it... if i trusted these guys with my car than i trust em with anything!!
give me a pm if you need to know any more info on em!!
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-246990
  • 3 weeks later...
Guest Qu!CkS!LveR
Dont know if this is of any help, may be a bit late but BODYFORM is Lansvale do Veilside kits. Dont know the price but the work is very good. Seen a blue R33 there that had the kit put on and it looked pretty good. Certainly worth a look if you are interested in the Veilside bodykit.......
https://www.sau.com.au/forums/topic/12934-veilside/#findComment-286237
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
