they have to make some money some how. so many people now just go to track days to watch and never go and pay to drive so i dont think it's so bad to make them chip in a bit too. :blush:
  • Replies 141
Sounds like you all had a top time.... it must be quite frustrating for the organisers to see a real surge in attendance to the track days and then all of a sudden it drops off when they up the number of days to meet demands.
I should be back out there with you all in about 6 weeks :blush:
Was it EC charging or the event organisers though? I'm happy to part with some cash to watch if its going to the event organiser to help cover costs but if its just EC (or OP) cashing in on the event then that is wrong.
The guy on the front said it wasnt the organisers, but EC wanting the cash
Which is the part i find wrong.
Yeah, but that lotus kicked his a$$ as well!
The lotus had more power than the good old NA Silvia, it was easily pulling away from me on the straight. Infact the good old silvia is so slow i was running it flat out through turn 1. Or maybe it just was the steel belts giving it extra corner grip :rofl:
Edited by Kero
It was the most amount of track time i have ever had at eastern creek, i would have keep going like Banzai but the rear brakes gave up the ghost the session after lunch. Must have been the kazillion laps we were doing at full pace. Ended up with best lap of a 1:49 which bettered my PB and was quiet pleased overall.
The lotus had more power than the good old NA Silvia, it was easily pulling away from me on the straight. Infact the good old silvia is so slow i was running it flat out through turn 1. Or maybe it just was the steel belts giving it extra corner grip :laugh:
mmmm...that silvia looks sexy with these shiny wheels
Not necessarily. The Lotus has less than 105kw at the flywheel which is about the same as a CA18DE (135ps). It's big advantage is lower weight. According to the sales brochure, an S13 with CA18DE weighs 1090kg which is more than 300kg heavier than the Lotus. The Lotus would also have been coming out of turn 12 at least 10km/h faster thanks to lower weight, wider tyres and better factory suspension set-up.
little do the punters know that the silvia is running a rb30e skyline motor good for a massive 114engine kw
works out about 80rwkw (and weighs 50kgs more)
another draw back of teh silvia is the gearing 6500 in 5th (about 200kmh) at the end of the straight (really the engine stops around 5k in fifth just past the diverge to the pit lane)
dont worry kids i now have the vl turbo kit in my possesion and the silvia will return with 240rwkw in a week or two.....
and some new r spec rubber
where going gtr hunting
1.47 or bust
Hahahaha - maybe tying up the exhaust would cut drag as well.
Fixed that..... I got black flagged as it came off the clips halfway through the day.
Found myself a nice bit of old snatch strap near a bin and it was all good again ;)
Edited by Kero
Found myself a nice bit of old snatch strap near a bin and it was all good again :O
Good on you Kero! I seem to remember you and Pete fixing it at Oran Park too!
I reckon Pete should give the car back to Emma for a week - she will take it in and get all the crap fixed to make it legal and drivable and you guys can claim it back again.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
