  • Replies 141
sticker set is $10 from race and rally or $15 from revolution. fire extinguisher you want a BFI 1kg dry powder type. comes with metal bracket. then it's just a matter of lifting your self up off the couch and bolting it in. ;)
so who did you get to install it barron
haha, i was going to get mark to install it but he said he had a date with you. probably going to get a team of workers from Gibson motorsport to do it.
Fatz you gay son of rajab, crack licking, ragged up, feltching, raging fag!
I have 1 additional player for Sat.
Shane (The part owner of the R32)
He will bring the $150 on Sat. It makes up the $50 difference on the brakes to make your Sh!tbox stop.
I have read the rules and the plastic ones are legal. The scruitineers don't seem to like them but they are legal.
that is good to know. all the scrutineers have always told me metal bracket only and that it has to stay in place under something like 25G (WTF?!) and be able to be removed by the driver with no tools needed (that means you fatz). but if plastic ones are ok now it opens up a lot more options.
oz, you are a massive baloney smoker but you hide it well.
I was just speaking to fatz, he made a good point, why do all his track day post turn into a b!tch fest?
My pesonal opinion is beacuse, he and most of his associats are a$$ bandits.
Beer B!tch, you and the ring leader!
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
