I know a lot of you guys would have alarms on your cars, but what extra steps do you take to try and prevent people from driving away with your car???? Like pulling something off the engine or installing a kill switch somewhere on the car. I have an alarm, imobaliser, club lock but still feel like i need something more....
https://www.sau.com.au/forums/topic/129373-extra-step-from-crims/
laser guns
Edited by Driver
I was away for 3 weeks recently and left my car parked unattended. I'm guessing you have a s2 r33 so dunno how this would work, i have a s1, with external ignitor so i took that off and put cling wrap over the plugs (to stop moisture getting in) - only 4 screws hold it in place. They cant drive the car off unless they have a replacement one handy hehe.... can still push/tow it tho if they are really enthusiastic.
The measures you have are all deterents and preventative measures...if they really want your car, they will get to it by hook or by crook if they can't start it they'll take it away on a flatbed.. One of the things I am very particular about is where I park. Choose your spots well and you should be fine. I'd drive around a carpark for half an hour if I have to jst to find the spot I want (close to shopping center entrances, where there are heaps of passers by etc...). And never park out on the road overnight if you can help it. Oh and hidden kill switch helps if you want to go that extra mile. :)
As all of the above are great ideas, most dont have good toilet training...
Trick is to make your car the least or less unattrative to steal.
So HIDE EVERYTHING. Cds, amps, anything and everything. Even loose change. Do not have anything visible, turbo timers etc as well. Steering wheel cover for a sports wheel. That will stop the smash and grab, or the 'this is easy to nick' people.
Park it where its hard to get. Multi level carpark for instance, no flat bed is getting in there is it. Park next to walls, means only one side of the car can get damaged by another car.
A good alarm also helps. Better yet, get your own wheel clamps. And put a parking ticket on the window. Whos going to steal that!
hahahaah Nice I love it :) thank for the input guys.
Alarm & Immobiliser
Kill Switch or 2
Park in visible spot
Park in between two concrete pilons or by a wall
Turn the wheels full lock if gone for a long time*
Steering Lock when exiting car; make it lock up
Club lock
Removable Steering Wheel
Chain in Wheel/s
* If they were to hit your car with a flat bed; the full lock would slow them down a bit (hopefully long enough for someone to realize what's going on)
direct wire to battery, and pull the extra 30v fuse...... no power to fuel pump = car wont start !
:wave:
edit: a local ezipark car park here in adelaidew had a car totally stripped clean late last year... was parked in an area the camera couldnt see.......................... they reckon it would have taken hrs to strip it. Doors, seats, wheels, electronics, etc etc etc
Edited by Tangles
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
