Ok very easy, disconnect you battery negative will do
and leave the door open so that the light is on and once you
take the neg. off the batt go and pump the brake
a fewtimes or just try to turn sumstuff on like centrallocking etc
just to drain allthepower from the caps in theecu and in the car and
then give it a fewminutes and simply re-connect and start car, go for a drive and alldone. :-)
Ok I just so don't believe in that method
1* Remove fuse panel on driver side
2* Locate the plug like in the picture below
3* Find a paper clip, Turn on the reds (don't start) Short circuit the 2 wires for 2 seconds. (WIRE COLOURED BLUE/BROWN)
Your ECU is now reset and in diagnostic mode. If you get 5 fast flash's and 5 slow flash's with your engine light all you sensors are fine. If not refer to the code list below. AND YOUR DONE !... With no stupid battery terminal removal.
Cheers,
Alex...
  • Like 1
i want to reset my stock ecu in my Series II r33 Gts-t so it learns that i have changed my dump pipe / front pipe / & cat back .. and upgraded smic ..
how do i do it and what is the procedure step by step?
plz help .. much appreciation
Nissans have no LTFT (long term fuel trim) capability, they are a dynamic system so only STFT (short term fuel trims) are learnt which means every time you power off it loses any of the changes it may have learnt. So in doing a reset it will do sweet f**k all in terms of fuel metering and most likely do nothing at all with ignition - but feel free to reset maybe it will fix you big end knock!!!
  • 4 months later...
Ok now im confused, does anyone have proof or anything saying that disconnecting the battery or shorting out the fuse thing actually reset the ecu?
i know its a long thread that people have been reading but does any of these actually work?
I aint no mechanic but yeah im sure more then just me would like to know.
Cheers M
The ecu contains form of memory that retains its state after the power is removed. No flash, no eeprom. There is no possible way it can store fuel trim maps between drives without constant power, which I'm quite sure that it doesn't because power is removed when the car is switched off.
I'd be looking elsewhere for your problem if you have one
Nissan ecu's do have a constant power feed direct from the battery.
I think people are grossly overestimating the capabilities of the ecu's self learning.
power still flows even after you switch off the car, that is why if you leave your car battry in without switching on the car for a month or so the battery will be drained
although how does resetting the ecu makes it re-learn? I think the ecu will retain its memory, just like your computer, you switch it off, pull the plugs, you don't find all your data lost..
if the ECU has self learning and STFT, wouldn't fitting the exhaust system automatically be recognised? so why bother to re-set?
that's what i've been told by a couple of tuners.
apparently, any learning that may occur will basically happen each time you start the car, although it's minimal to none. The ecu just isnt that smart.
  • 5 years later...
I was under that impression too, it is a closed loop system and changes dynamically to achieve stoich. Timing is a fixed map and only retards on knock detection.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
