I know. before you say it, i have used the search.
What i need to know is if i cut sire #53 on the ecu, however i have heard that this disables your HICAS. Since i like HICAS how else can i remove it, or will cutting the #53 output fix this, Has anyone done this? If so does it work.
ALSO how do i remove the Boost cut and how does the boost cut work. I was going to get one off these, Gizzmo FCD,
http://www.nzperformance.co.nz/store/view_...hp?product=GFCD
But i have no idea where to get one here in OZ. Are these worth it, and do they work well.
How does the boost cut work and when does it come on or how is it determined by the ECU that it needs to be on.
OK thanks. This is a bit urgent, i need to get the car ready for track in two weeks.
https://www.sau.com.au/forums/topic/129402-speed-cut-and-boost-cut/
I forgot to mention that it is a 95 R33 GTST.
I have a friend who is a wiz with electronics, so he can make something for me, just not sure how the boost and speed cut work?
Can somone clarify how the speed and boost cuts wort on a R33?
Boost cut is the wrong term for it, as the 'cut' has nothing whatsoever to do with boost/pressure levels.
The right term is "Rich and Retard" - do searching in the forum on this term instead of "boost cut" and you may find better, more technical answers, especially from Sydneykid.
Basically when you turn up the boost on the RB25DET, your fuel/air mixtures will be very rich at the top end (down to AFR of 8-9). The ECU will then retard the engine as a reaction to overly rich fuel/air mixtures.
The new Turbosmart FCD works a charm so I've heard; perhaps call them up and get some more details on it.
The Speed Cut can be removed by simply cutting the wire; look up the ECU pinout manual to find out which one.
only problem is i have no money for a PFC, but enough left to get a SAFC II, plus sometimes these come up cheep.
UPPPSS i better tell my mate not to cut the wire, he was goign to do it, but has an auto.
Thanks mate.
Either way, would using a SAFC II to lean out the mixture, fix the boost cut retard?
a mate of mine cut a speed wire (don't know which 1) and it got rid of his speed cut.
as for rich and retard, a safc won't get rid of it. it has nothing to do with air/fuel mixtures. it is to do with the amount of air passing through the airflow meter at any given rpm. it isn't just when you get to a certain pressure it cuts out. the amount of airflow might be ok for 4000rpm, but its too much at 3000rpm, so the ecu kills the engine for a second to slow the turbo down. then the engine will kick back in and continue on as if nothing has happened. you don't lose power after it has happened, just for the time that it kills the motor. when mine would do it it would proceed to light the tyres up down the road when it kicked back in if i was in first or second gear.
i would also have to suggest the new turbosmart fcd over any of the others i have seen, as it has a set of instructions just for skylines.
but ultimately a full ecu, or a remapped ecu would be better. i picked up a remapped r33 ecu for $200. it was remapped in japan. it has no speed cut, higher rev limiter and no airflow protection.
So the cut, feels like a missfire then, or what? The car will be in Tassie on Monday, and as soon as it comes in, it's getting a new IC, new exhaust, boost regulator, fuel pump. I am planing on running 10-12psi on the stock turbo for now.
What are my chances of incountering boost cut, and is there an easy way to get rid of it.?????????????????
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
