I need to change insurance companies but noone likes to hear about my driving history. I guess its my fault cos Im no angel. And Just Cars suck for 3 reasons;
-Excesses are excessive ($3k for me which is bordering ridiculous)
-The agreed amount of insurance is ~ redbook (they dont seem to understand that mods are expensive stuff eg rims)
-No monthly or bi monthly installments (just great with the insurance premiums suck to begin with).
Ah well, I haven't had trouble with them for the past 4 years though. Anyone should I bother calling you guys reckon?
People just to let u know about H2P insurance (in conjunction with RAA). They are cheaper then Just cars etc and many others. Im currently P plator n drive Series 2 R33 NA GTS4. Compre insurance = 1g. I contacted them 2day advising them im modifying my engine via adding a turbo kit. Asumming my preimum will go up in the hundreds... suprisling it was $0.00 (any mods under $4,000g doesnt affect). They were nice people n knew about skyline etc... lol. Give them a Try.
(08) 8202 4393
um i just rang them and well they said you adding a turbo WILL increase your excess and premiums
and they wernt cheaper than just cars for me
2 strikes your out :wave:
on a side note rang famouse and am happy with there quote of $702 with agreed value of $20,700 and excess of $1000
my agreed value with just cars is $16,500 :woot::rolleyes:
i used to be with just cars. the premiums are bad enough.. but the excesses are a joke.
Changed to Shannons; was 50% less premium with a $500 flat excess, monthly payments and choice of repairer.
WIN!
You might wanna give _8OO5TED_ a PM. He works for Shannons (or did when I changed over).
err actually he's changed positions just recently.
info here: http://www.skylinesaustralia.com/forums/in...t&p=2284980
Bare in mind though, if you're under 25 most insurance agencies will give you a hard time, especially if you have minimal insurance history. Also, the cheapest premium might not necessarily be the best one to go with when it comes time to make a claim.
my 2c :D
Edited by GFXman
naw not under 25 not even under 30 anymore
shannons wont insure my vechile they claim im in a high risk suburb
he was also asking if i went to car shows drags drifts and stuff, i asked him why he wanted to know he claim to make a connection as to why i bought a import skyline (im thinking risky behavour)
just cars for me was 800/ year 1500 excess and only 16,500 agreed value (which i didnt agree too)
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
