hello there,
i was wondering what would be better, semi slicks / slicks on the standard r33 16" rim or on a pair of 17" x 8" wide.
just wondering because the rims are wider but the stockys would give more flex in the wall?
im talking about better grip to give better ET times...
:D THANKS YO!
https://www.sau.com.au/forums/topic/129433-slicks-mate/
man is thi for the track or the street?
but if its for the track , what i have learnt from all the boys that race is to get the least side wall possible to make it better for cornering so for a wheel say like all the gtr standard wheels are 17" 9" you run a 235 40 17 semi comp and this is said to be better then putting a 255 on the same rim.
but this is only info i got from the boys who race most weekends
just my two cents
https://www.sau.com.au/forums/topic/129433-slicks-mate/#findComment-2393836
if it is for the strip you'd be better off getting a set of 300zx wheels. they are wider than the r33 wheels, and will hold a wider tyre better. for the strip you want a bigger sidewall for traction, and run them at low pressure (around 16-18psi)
https://www.sau.com.au/forums/topic/129433-slicks-mate/#findComment-2394062
yeah thats what i thought BUT what i was asking is... is it better to have semi slicks on my 17" x 8", most likely thinner side wall (im guessing this would be better for track)
or
the standard skyline rim which i think are 16" x 6" with semi slicks with a thicker side wall (just to get alot of flex plus running low pressure...)
but the 17" are thicker... would that compensate or the 16" with the more flex in the side wall no comparison??? >_<
https://www.sau.com.au/forums/topic/129433-slicks-mate/#findComment-2399384
Semi-slicks are generally circuit tyres.
Drag Radials are for drag racing.
Both have a completely different built type, the semis have stiff sidewalls and the drag radials have very very soft sidewalls to give that flex for the traction.
Get a set of 300zx or 32 gtr rims and buy some M/T or BFG drag radials.
PM me if you are in Sydney and interested in 300zx rims with Nitto Drag Radials.
https://www.sau.com.au/forums/topic/129433-slicks-mate/#findComment-2399502
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
