warpz0r, my understanding is passing emissions does not necessarily mean absolute best fuel economy (hence your lean comment).
Ign and afr's affect the levels of different gas the motor expels.
It must be tuned correctly; and emissions test is not done on boost, so plug in the stock ecu and pass that emissions test. :dry:
Thats my limited understanding. :)
I haven't actually seen the ecu thread on calaisturbo.
The RB30DET actually runs fine behind an rb25det ecu, on boost afr's are quite nice and it simply just runs.
Providing the motor has been setup with factory like squish/quench there 'shouldn't' be an issue passing emissions on the stock ecu.
The Rb20DET ecu however struggles as its airflow map has not been designed to see anywhere near the airflow levels the 3ltr pushes at low rev's. as a result it fuel cuts very early in the piece with only 6-7psi on a stock rb20det turbo.
Then there's the cost of an emissions test.. So as Nismoid put it.. not feasible/possible :D
EDIT: I'm having a read of the ecu thread now.
http://www.calaisturbo.com.au/showthread.p...t=ecu+emissions
in NSW the emissions test is free...
so hyperthetically speaking - having my rb30det emissions tested using a rb25det ecu with stock injectors and my current turbo (hiflow) boost limited to a lower psi should get within an acceptable range providing i switch injectors to stock and maybe put a brand new cat converter in place?
What about the fact that you have 0.5 L more capacity - it will be lean which increase HC which increases the chance of failing.
Why would it be lean?
Airflow is relative, it sucks x volts through the afm it drops in y amount of fuel.
On the stock ecu my afr's on cruise and light throttle etc were all perfect, on boost as I said prior it would fuel cut.
Another bloke in the early days of rb30det conversions simply dropped a rb30 bottom end under his r33 rb25det head, all still with stock inj, ecu, turbo etc.. AFR's were all good. Ran fine and with a slight increase in cas ign. timing it made close to 200rwkw, same as the rb25 he had prior just with a lot more area under the curve.
have noticed that lean ups the ratio of another gas .. cant remember which one..
this will sound bad, but to pass a CA18 in a sprinter we had a copper pipe attached from the turbo outlet pipe, onto the exhaust pipe..
so it basically pumped fresh air into the exhaust ready for them to read :D
i gues that would suffice if your desperate... just know how much Moanie on teh forums had to go through with Hitman to retune the car over and over to get it to pass and that was on a 240rwkw RB25
Really there was no jerky ness or drivability issues - its more to do with throttle enrichment as its based on TPS enrichment not airflow, also cranking fuel as its pulse width vs ECT.
No jerkyness, no dead spots nothing just smoot, like factory. it was all perfect.. Mine was on the rb20det pfc and this other dudes was on the r33 ecu. mr_rbman also ran his in on the stock rb20 ecu. Ran started and drove fine.
Prior even with the rb20det I had a cold start issue that too carried over to the rb30det where it would fire then stumble. The only fix was the pfc. I would have most definitely noticed any drivability issues as I ran the stock ecu on it for 10,000km's.
I've got vids of it driving.. Nice and smooth, if anything it felt as if it was punchier off idle with the stock ecu vs the pfc.
No jerkyness nothing smooth.. it was all perfect.. Mine was on the rb20det pfc and this other dudes was on the r33 ecu.
Fair enough - I've got to admit though I do almost halve throttle enrichment in both the PFC and standard ECU, but not in all cases.
Its a good discussion though as I will be trying to pass my rb30/26 with the standard ECU retuned by me.
Edited by rob82
yes the pfc does tend to run quite rich throttle enrichment, unsure on the stock ecu. But as you say if you pull nearly half then there must be a little head room where it just happens to work ok with the rb30det.
Care to share what values you found to be near optimal with the pfc? :D
Off the base pfc values mines running a tad less than std. But I still think it may be a tad rich, haven't really had much of a fiddle with accel enrichment as of yet.
Just as a guideline enlearn it until it drives shitty. It's different with different mods - injectors, airflow meter plenum size and so forth.
Any quick tips on how I should do this as there's the amount and decay value. I simply pulled out a little decay, made no difference to feel. :S
No pull the pulsewidth value out - the decay you need to have a drive and a feel and watch your mixtures with a wideband. The decay is mainly used to enrich for the time it takes the manifolds volume/ pressure to stabalise. So for a properly mapped system the mixtures wont change with any amount of throttle disturbance.
Sure you could tune it to meet an emmision standard, but what one, one from 10years ago?
It wouldn't go anywhere near meeting current emmisions standards for manufactured vehicles.
They had to build newer NEO engines for a reason and drop the SR20 altogether.
About all you can do is use a good 3way catalyst, set your ecu up for closed loop control to target a 14.7:1 AFR when cruising and enjoy reduced fuel usage and cleaner emmisions during this period when the engine is warm and knowing that your car would pass an emmision test for cars from 1986 that only required closed loop and a cat.
Better then not doing anything, but in reality a few modified cars contribute bugger all to greenhouse gas when compared to industry and coal powered power plants.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
