gday guys and gals,
currently doing the runs and gathering all the parts for my 100k service. Heres the list that i have come up with so far, just missing some part numbers for the others. if anyone can fill these in that would be great. Tried the search and stickies but didnt find any answers to my questions.
Tensioner NSK 60TB0683 EA7L 806
Idler NSK 56TB2801B01 ENSL 309
N1 oil pump 15010-24U00
Norm water pump 21010-21u25 or N1 water pump 21010-24U27
Ancillary belts ??
Gates Racing timin belt T1040R?? how much and where from??
Seals and stuff ??
Just want to know if there are any seals and the like that need replacing? Part numbers please?
Is it necessary to replace the oil pump too or can that be done later when needed?
Is the N1 water pump overkill for a street car that sees the track once a while? Issuses with cavitation under normal street driving.
How does everyone rate the Gates Racing timing belts compared to those jap aftermarket ones? Just as long as theyer tougher than the original ones, dont really care what brand it is.
thanks for putting up with another 100k thread. :wave:
https://www.sau.com.au/forums/topic/129484-seals-and-gaskets-for-100k/
i just done my 100k service i replaced the tensioner and idler bearings used a standed nissan belt and standed nissan water pump and replaced all the fan belts .didnt think anyone replaced oil pumps at 100k
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
