Hey everyone .
Just wondering on your thoughts on wether I should get a 3inch or 3.5 inch system for my GTR .
Plans are mild mods , HKS GT-SS or 2560r lowmounts and support systems to match that sort of setup . no internal changes at this stage.
Obviously bigger is better but I have found a big price jump in the 3.5 inch system so is it worth it ?
It really relies on what power goals you are after with all the mods you plan to put into it.
If its say under 300rwkw then a 3inch should be fine without restricting air flow.
Im guessing the the difference between a 3inch to a 3.5 inch is something like an extra $500?
3.5" :D
If using twins, just run a twin exhaust of a smaller size :O
i don't get it...... . .. . .
" if using twins " you mean if your putting it on a twin turbo car?? like his gtr??
sooo on a gts-t *single turbo* 3.5" is quite desirable
sooo can i go for a 3.5 on a gts-t with less than 200rwkw's?
better spooling right?
aaand quick question cuz u'v help't me sooo much in the past 2 weeks..
* iz turbo fluttering bad for my turbo? because i block't the bov off and i LUV the sound it makes
plus doesn't it increase spooling because the pressure aint going away completely?
dont hijack my thread dude!
:D
i dont remeber of the top of my head what other people with gt-ss/2560s are making but i dont want more than 3-350 max rwkw and i dont think those turbs will get to 350 anyway
it was about 700$ extra fitted for the custom 3.5inch system over the 3
but bear in mind that for a gtr that system is only going to be 3.5inch from the cat onwards , the twin fronts will probably be about 2.25 on both systems . so it seems like a lot for just a bigger cat and catback . especially given some of the 3inch metal cats are flowing huge numbers , far greater than a traditional ceramic cat in even 4inch
Hey,
As someone else said a long time ago, oils ain't oils ;) Not all 3" and not all 3.5" exhausts are equal. If you
can find something that expands from the turbo outlet at 7deg angle to the sizes you want (say expanding
to 2.5" on the dual pipes, merging to 3.5" then through a 3.5" high-flowing cat), you are in luck.
A turbo will work the best with pretty much nothing behind it - you of course can't do that, so the bigger, the better.
Bigger usually means more noise, so you need to factor that in - my old 4" is 95dB@3500 - and that's with the turbos,
twin cats, a resonator and muffler to shut it up. My old exhaust isn't really suitable for a road car - very deep, nice
note - but very loud.
Personally if you can put up with the noise I'd go for 3.5" - it depends what your needs are. The difference in top end
between 3" and 4" is noticeable - so I'd guess this would apply to 3.5" too (all other things being equal).
Given that you're concerned about cost a dual 3" is probably not an option for you? If the price difference is so big
you might want to ask about that...
Regards,
Saliya
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
