Originally posted by KamikazeR33
my cruise?
im only a visitor :P
well u know the best parts of canberra to go as i dont :(
i havent been there in a few yrs
also shell u know u like lookin at bums waving at ya :P
yes your cruise! so i'm gonna shut up now and let you organise it :P
hehe just kidding...
well looks like a few ppl are keen, which is good
and poyz...would love to see other imports there!
Justin, it ages away, so i'll try to think of a route/meeting spot when i have some time okies?
and as for having bums waved at me...Birty stuck his butt out the window of slips R31 last time i was in QLD (I was next to them in a balck R33) and it scarred me for life :spew: hehe :D
https://www.sau.com.au/forums/topic/12951-cruise/page/2/#findComment-265016
Luke, welcome to Canberra (and SAU)! :P
Justin, yeh I will bring some membership forms if anyone wants one, but if u want to fill one out beforehand, just download it from the link in my sig...then you don't have to stuff around filling it out on the day.
https://www.sau.com.au/forums/topic/12951-cruise/page/2/#findComment-280673
luke, i work in printing, we pretty much run 24hrs
I finish at 2am (usually - depends what time i start)...so when i get home i have a late dinner & surf the net and stuff...teli sucks at this hour of the morning :uh-huh:
https://www.sau.com.au/forums/topic/12951-cruise/page/2/#findComment-282638
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
