hey guys, as above my coolant over flow bottle is almost at the max line, i swear it wasnt that full the other day.
does this mean my car is over heating?
also, does this mean i should do a coolant flush and put new stuff in? im getting it done aswell as the water pump when i get my 100k service.
how do you empty the coolant overflow bottle? hehe sorry for the noob questions.
my car is a 1996 r33 gt-st
cheers
also my car does NOT have a fan shroud, would this be causing the fan to not cool the radiator as much as it should?
Edited by hayden49
cheers
When the cooling system cools down, the water will be forced back in.
More than likely.
oh ok so it will just flow back in by itself?
it freaked me out abit cos i have never seen it that high, i did however give it a good punishing on the way home from work then i was stopped in some heavy traffic.
also, my r33 came with only the engine fan, did 33's come stock with another thermo fan?
im gonna get the coolant changed when i get my service done and give it a flush and see how it goes.
oh ok well my car doesnt have air con anyway, the condensor was removed when the guy imported it.
ohwell one ill get round to fitting a new one.
so this all sounds normal?
the level has gone down abit already.
cheers
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
